lcfitt(at)sbcglobal.net Guest
Posted: Sat Oct 14, 2006 3:20 pm Post subject: Ethanol and fiberglass tanks - once again |
Guy's experience is similar to mine, though he is in the business and
probably has a better heads-up than I do. My research has found several
formulations of vinyl ester resins. The two that come to mind are alcohol
resistant and electrically resistant.
The resin sold in ACS is a DOW product and has been used in highway bridge
studies. I personally need it in oz. quantities and the smallest quantity I
have found is the ACS gallon. The down side of this material - all vinyl
ester resins - is that they are "activated" before use and the hardner is
the usual "peroxide" used with polyester resins. After activation, the
resin has a shelf life of 90 days.
I will use one or two ozs. and then toss the rest of the $65 gallon.
If anyone knows where to get this stuff in relatively small quantities, you
will be doing me a great favor and likely others on the list as well.
Lowell
dafox(at)ckt.net Guest
Posted: Sat Oct 14, 2006 6:44 pm Post subject: Ethanol and fiberglass tanks - once again |
I still think ethanol is not the answer.... It is just a corrosive
diversion to get a few more votes.
Noel
I agree with you 100 % David Yeamans
Float Flyr
Posted: Sat Oct 14, 2006 8:50 pm Post subject: Ethanol and fiberglass tanks - once again |
Glass is an organic compound???? Mostly silicate when I went to school.
Not a carbon atom to be seen.
For the record I didn't say cars weren't getting better only that there is a
lot more engineering that goes into making a successful plane than into your
run of the mill Ford or Chev. And yes you better believe there are parts
that the manufacturers expect to fail inside the warranty periods. The cost
of their replacement is built into the cars. Most new front wheel drive
cars, except for the real cheapies, will have their front drive shafts (CV
Joints) replaced within the warranty period. That all depends on how the
car is driven I guess.
Then I'm at 50' or 3000' I don't need to worry if the innards of my tank
will plug my engine. You may take that chance.... I won't. I want to see
some real experimentation done with some real figures. In the meantime I'll
err on the side of safety ( if I've erred at all) If that bothers you ...
It should. And perhaps you should stand back and have a look at who is
saying what....
Yes car warranties have been getting longer and cars them selves have been
getting lighter. There is more plastic on and in new cars than you can
shake a stick at. Most of this plastic is a great improvement in design.
E.g. the composite springs found on the back of some mini vans are quite
strong at a fraction of the weight of the old steel ones. All wheel drive
systems are finally coming into their own. Etc, etc... They still have a
long way to go to catch up with aircraft design engineers.
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Sat Oct 14, 2006 8:54 pm Post subject: Ethanol and fiberglass tanks - once again |
I wonder what will happen if they find out in fifteen years all those
underground composite tanks start to decompose???
Yes don there are no assurances as to what it is you have there and worse
than that changing tanks further down the road is a fairly big time
consuming job.... Especially when you'd sooner be flying.
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Sat Oct 14, 2006 9:01 pm Post subject: Ethanol and fiberglass tanks - once again |
Gee! The booze around here doesn't get to stay on the shelves very long so
how do we know the plastic bottles will stand up to a few minor things like
exposure to ultraviolet light, famous for breaking the molecular bonds of
just about any plastic and temperature changes, not to mention vibration.
Yes we can protect our tanks from the UV easily but we have the right to
know what we are getting into before we commit.
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Sat Oct 14, 2006 9:02 pm Post subject: Ethanol and fiberglass tanks - once again |
So why would any one in their right mind want to put ethanol contaminated
fuel in these tanks??
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Sat Oct 14, 2006 9:04 pm Post subject: Ethanol and fiberglass tanks - once again |
Yours seems to me to be the only independent experiment I've heard about.
Great.
Noel
[quote] --
Kitfox III-A
Float Flyr
shilocom(at)mcmsys.com Guest
Posted: Sun Oct 15, 2006 6:19 am Post subject: Ethanol and fiberglass tanks - once again |
Lowell, Just curious where you got 100% ethanol. Even our plant in Mo. can
only sell denatured alcohol which I believe is something above 98%, to keep
the drinkers from using it. Also what is 6% mogas. Do you mean 6% ethanol
and 94% unleaded gasoline. I've got a Model IV, 9? fox, whatever year
they changed tank material, I'm rebuilding that I'm not sure of the tank
composition, and am trying to decide whether to replace the tanks or slosh
with the PR-1005-L Buna N that seems to be working so well in my combine.
Bob U.
Posted: Sun Oct 15, 2006 6:27 am Post subject: Ethanol and fiberglass tanks - once again |
For those who don't believe in ethanol to "reduce" foreign oil dependency, they should suggest and PROVE another PRACTICAL alternative. I'm hoping, but probably only a big hope, that Hydrogen will prove out quickly. Bob U.
Posted: Sun Oct 15, 2006 7:42 am Post subject: Ethanol and fiberglass tanks - once again |
Bob, You are correct on the 100%. I am using denatured alcohol, wasn't sure
of the percentage, but my reading said it acts the same as 100%, what ever
that means. I had been lead to understand that the denaturing agent is
methanol. I suppose I could get pure ethanol from a pharmaceutical supply
co. But I no longer have a license to practice dentistry. We used to use it
in the old days for gold foil fillings.
The 6% mogas did refer to 94% petrolium fuel and 6% ehtanol. Sorry for the
misunderstanding. I tried to boost the 6% ehtanol to 25% (arbitrary) by
simply adding the denatured alcohol to the pump fuel, but it won't mix.
This is one of the fears of higher levels of alcohol in mogas as I
understand it. My reading indicates that the alcohol is added to the
gasoline just prior to shipment to prevent water from getting into the
alcohol in the stored fuel. There is a tendency for phase separation and
when transferring from the truck to the underground tank if not mixed
completely, the first out of the truck would by higher in ethanol by
percentage, as ethanol is more dense than the gasoline and settles on the
bottom like water.
Lowell
Posted: Sun Oct 15, 2006 12:08 pm Post subject: Ethanol and fiberglass tanks - once again |
<<<Just curious are they (the refiners or governments) putting any thing
into
EA85 to make it either poisonous or un-palatable? Could make for a cheap
weekend >>>
15% gasoline!!!!
<<Corn in
| Quote: | usable quantities won't grow here and the cost of transporting Eth from
the
| Quote: | closest distilleries would be prohibitive.>>
1/2 of our production in Malta Bend Mo, 45 Million gallons, soon to go to 90
million, now goes to California, so the east coast is no farther away.
Bob U.
Posted: Sun Oct 15, 2006 12:20 pm Post subject: Ethanol and fiberglass tanks - once again |
You know a lot more about it than I do chemically. I know we ship the
denatured product in tanker trucks and rail cars to "blenders", where the
15% gasoline is added to get E85 or 85 to 90% unleaded gasoline is added to
get E10 or E15. I've been running around 30% ethanol in an OLD 88 T-bird
for a couple of months by haphazardly blending E85 with unleaded gas at the
fuel pump. I guess at how much fuel it will take total, add about 30 to 45%
E85 and then fill it up with nonleaded gasoline. Has taken away a lot of
the misses and hesitations of the old bird, but don't know how much less
fuel economy I'm now getting. I'm playing around with getting a "blenders"
liscence here on the farm, so I can get the 51 cent Federal tax credit. I
own several shares in an ethanol plant close by, but the problem is they
can't load small trucks like mine, so would have to go thru a jobber and
they don't want to give up the lucrative tax credit much at all to sell to
me. Don't know how it will come out in the wash. In case you are not
familiar with the USD research and web site on AGE85, here it is. AGE85 is
Aviation Grade Ethanol and doesn't necessarily mean it is 85% ethanol, but
some time gets much higher, approaching95%. They have 3 airplanes running
on it doing reasearch for the FAA. http://www.age85.org/ Bob U.
pwmac(at)sisna.com Guest
Posted: Sun Oct 15, 2006 2:19 pm Post subject: Ethanol and fiberglass tanks - once again |
They use polyethylene
PW
At 05:33 AM 10/14/2006, you wrote:
Noel, you might note that GM and Ford have intentionally designed some of
their vehicles to run on E85.
Don't know what their fuel tanks are made from, but I'd bet that the car
companies are WAY ahead of most aeroplane builders with regards to this
issue.
Brian
Float Flyr
Posted: Sun Oct 15, 2006 5:13 pm Post subject: Ethanol and fiberglass tanks - once again |
Reduce dependency at what cost??? Cheaper to start using diesel engines in smaller domestic cars. The VW TDI jetta is quite popular here north of the 49th, as is the Mercedes smart diesel (if you can find one)
Still takes more than a gallon of diesel to produce and deliver a gallon of hooch In my book that's a net loss. Those working for the ethanol producers and the oil companies will say other. they are well versed at twisting the figures.
Noel [quote]
Kitfox III-A
Float Flyr
Posted: Sun Oct 15, 2006 5:19 pm Post subject: Ethanol and fiberglass tanks - once again |
All the large ships are busy moving oil. We can't grow the corn here and
the costs would be prohibitive. "Thank god we're surrounded by water!!" (
that was an Anti-Confederation song 57 years ago.)
Noel
[quote] --
Kitfox III-A
Posted: Sun Oct 15, 2006 5:33 pm Post subject: Ethanol and fiberglass tanks - once again |
Good post
Let me call attention to pages 20-22, where the
vapor pressure is noted for auto fuels. Keep in
mind that high vapor pressure means low boiling
point and higher risk of vapor lock. It is my
belief that these tables apply generically to
auto fuel not just E85. To much work to prove this point.
Class 1 is for hot weather where a high boiling
point is desirable and class 3 is where it is
cold and a low boiling point is OK. The you can
look at your location and see why it is important
in a plane to make sure one uses the highest
boiling point fuel that you can buy. Example when
traveling S from CO get your fuel south of 34 deg
latitude in NM. Or even better plan to be low
just for that purpose. Then when one get to AZ
fill up with the high boiling point fuel.
Regards, Paul
At 03:17 PM 10/13/2006, you wrote:
Hi Michel,
You're pointing to a very important problem -soon to come...
First, the PRC 1422(a..B) Pro-Seal, is a well known fuel sealing compound
much used for both jet fuel and 100LL. This compound is mostly used as a
sealer between joints in wet tanks, but also as a sealer for fasteners
etc. inside fuel tanks. The PRC 1422 "never" harden, but will keep it's
good elastomeric qualities for a very long time.. The problem is that
it's a stuff with "high" viscosity, I.E. cant be sprayed.
Here's a link to the "famous" site :
http://www.bergdahl.com/Aerocat.htm
Now to the problem, the ethanol fuel E85.
I do not think this kind of fuel can be used for "today’s" aviation.
Firstly, we'll need to find out more accurate information about various
Resins vs. Ethanol and "fiberglass degrade".
So, what kind of resin is used in YOUR Kitfox??? My Kitfox model II (93
mod) is made with West System Resin (the fuel tanks).
Well, here's a little info, copied from the "official" guide, issued by:
The U.S. Department of Energy
Some materials are known to
become degraded by contact with
fuel ethanol blends having high
alcohol concentrations. Zinc, brass,
lead, and aluminum are some of
these sensitive metals. Terne (leadtin-
alloy)-plated steel, which is commonly
used for gasoline fuel tanks,
and lead-based solder are also
incompatible with fuel ethanol.
Avoid using these metals because of
the possibility of vehicle failure or
fuel contamination. Unplated steel,
stainless steel, black iron, and bronze have shown acceptable
resistance to corrosion by ethanol.
Nonmetallic materials that degrade when in contact
with fuel ethanol include natural rubber, polyurethane,
cork gasket material, leather, polyester-bonded fiberglass
laminate, polyvinyl chloride (PVC), polyamides, and
methyl-methacrylate plastics. Nonmetallic materials
that have been successfully used with fuel ethanol
include Buna-N, Neoprene rubber, polyethylene, nylon,
polypropylene, nitrile, Viton, and Teflon.
You see, aluminum and brass (our carburetor), is among the material that
won't stand the Ethanol...
Ok., here's the link to the full document about Ethanol fuel (E85):
http://www.agriculture.state.ia.us/pdfs/ethguide.pdf
This is recommended reading for every one of us.
Torgeir.
A happy model II flier, with Avid wing , sure you too Michel...
On Fri, 13 Oct 2006 19:55:00 +0200, Michel Verheughe <michel(at)online.no>
wrote:
>Greetings, Kitfoxers,
>We have been talking about the danger of ethanol in our fiberglass tanks
>for a long time. I have already mentionned what I read on the Jabiru
>Engine list but ... here it is again:
>A gentleman called Bill Evans writes:
>"The airlines, military and others use thiokol based rubber sealants to
>seal their tanks. Brand names is PRC. You want PRC1422 A2. It's now
>manufactured by ProSeal. Normally lasts for generations."
>To what I reply, as previously said on this list: "Yes, but it can't be
>sloshed in our existing tanks."
>To what Bill answers:
>"So the PRC is not thin but is pourable. The solvent is Methyl Ethyl
>Ketone. (You can only do this outdoors and with the wind to your back.)
>MEK is somewhat soluble in PRC. You use a paint mixer in an electric
>drill, and thin the PRC with MEK until the sealant will flow
>sufficiently to get 100% coverage. Slosh would be too optimistic. You
>could also spray it in with a new garden sprayer, but that would also
>"seal" the future of your garden sprayer. I have done this... Sprayed
>PRC."
>Guys, my brain is as empty as a barrel of beer after being raided by a
>bunch of Norwegian soccer hooligans! Make up your mind on the above
>information and let me know what the jury has decided. Can we do it?
>Thanks in advance,
>Michel
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
janderson412(at)hotmail.c Guest
Posted: Sun Oct 15, 2006 5:52 pm Post subject: Ethanol and fiberglass tanks - once again |
Yep, chucked my LAST petrol car for a C5 Citroen HDI diesel and has to be
one of my better decisions...The common rail turbo diesel technology has
come so far, performance and economy is over whelming
Subject: RE: Ethanol and fiberglass tanks - once again
Date: Sun, 15 Oct 2006 22:41:19 -0230
Noel
