Float Flyr
eskflyer(at)lvcisp.com Guest
Posted: Mon Oct 23, 2006 6:21 pm Post subject: need info on 582 rebuilding |
How do you guys come up with this crap when a ? was asked . at least change the heading to suit your post geeeeeee.
John Perry tired of the drivel
and why not use the DO NOT ARCHIVE
DO NOT ARCHIVE
wingsdown(at)comcast.net Guest
Posted: Sat Oct 28, 2006 7:22 pm Post subject: need info on 582 rebuilding |
BY no means do I know much about 582s, but I thought the crank was a
disposable, non-turntable item.
Rick
Posted: Sat Oct 28, 2006 8:39 pm Post subject: need info on 582 rebuilding |
Rick ,
every part for the 582 crank is available its just finding them the hard
part . the 582 mod 90 is easy to find parts for . The 582 blue head still
looking to find the rods and needle bearings for crank end . Correct me
someone but if I am not mistaken the 582 blue head crank is the same as the
618 crank ?.
fly safe fly low fly slow fly fun fly KITFOX
John Perry
Kitfox 2 N718PD
TD/ Straight floats
582 C box 2:62-1
DO NOT ARCHIVE
occom
Posted: Sun Oct 29, 2006 2:17 am Post subject: need info on 582 rebuilding |
I understand that the connecting rods used on the 582 are unique to that
engine and are not sold at all. The old style rods will apparently hit and
break the crankcase when the bearings get sloppy.
Posted: Sun Oct 29, 2006 4:48 am Post subject: need info on 582 rebuilding |
Dave,
Which 582 are you talking about the new mod 99 or the old style mod 90 ?. Or
another way to put it the gray head , or the Blue head engine ?.
JP
DO NOT ARCHIVE
occom
Posted: Sun Oct 29, 2006 7:53 am Post subject: need info on 582 rebuilding |
You'd have to ask an authority like CPS. I simply know they changed them and
do not sell the rods separately, only as part of a crank assembley. I've
seen this in print several times and it is repeated in a service video I
have. I believe the change was before the mod 99 but again, I'm no expert.
dave
Posted: Sun Oct 29, 2006 8:08 am Post subject: need info on 582 rebuilding |
Call me dumb, but i just send engines to Bob Robertson and get new crank at
300 hours.
No worries or failures to report of yet.
I leave the trials and errors up to the experts.
saving 500 to 1000 $ is good sense until you sepnd more on repairs.
I saw a guy a month ago same thing - refused to listen and now he needs one
new wing plus repairs to fuselage and recovering.
Yah good way to save a few dollars. And I almost always get a kick out of
the AP or AME rebuilds on Rotax engine ( other than one certified on Rotax)
Just casue they a aircraft mechanic does not mean it will work .
To each their own. And Dave CPS is USA side of border and will most likely
be more expensive than sending to Light Engines ( BOB R ) in Alberta.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
akflyer Guest
Posted: Sun Oct 29, 2006 8:15 am Post subject: Re: need info on 582 rebuilding |
dumb......you told me to....
occom
Posted: Sun Oct 29, 2006 9:03 am Post subject: need info on 582 rebuilding |
Yes, CPS is in the states, what does that have to do with their expertise? I
think many of those asking are also in the U.S.
BTW, I agree, following the recommended service program is probably much
safer.
Float Flyr
Posted: Sun Oct 29, 2006 9:28 am Post subject: need info on 582 rebuilding |
Certified engines have manuals that are very in depth for every procedure
that is to be done on the engine. As far as I know there is no such manual
available to non-Rotax technicians. The local Ski-Doo shop will probably be
as good as a certified AME or A&P on the two stroke.
I have had dealings with Bob Robertson and I'm not the slightest bit shy
about recommending him to any one with a two stroke Rotax. These engines
are about as far divorced from the four stroke Lycs and Conis as possible
and still have pistons. They are really specialist engines and require a
specialist approach to repair.
Noel
AME intern
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
akflyer Guest
Posted: Sun Oct 29, 2006 12:19 pm Post subject: Re: need info on 582 rebuilding |
how can you lend any credibility to the "recomended service program" that varies by what country you are in ???? Every where else in the world the TBO on the crank is 600 hrs, but in the US we must do something terrible to our engines as we can only get half that out of them... please....The recomended TBO is based on a half life. After the 600 hrs things start to get dicy so to remain ultra conservative in our sue happy country, they say to replace at 300...this is to cover the manufactures butt not ours...
by all means if it makes you feel better replace at 300....
dosmythe(at)cox.net Guest
Posted: Sun Oct 29, 2006 1:50 pm Post subject: need info on 582 rebuilding |
Just to help out your point. I overhauled my 582 at 300 hours (including
crank). I was chasing a problem at the time and that was the reason for the
overhaul. Turned out, the problem was not even in the engine (another
story). My old 300 hour crank showed no wear what-so-ever. As a matter of
fact, the engines speced out in-spec. Did not need an overhaul......
Don Smythe
Malcolmbru(at)aol.com Guest
Posted: Sun Oct 29, 2006 6:18 pm Post subject: need info on 582 rebuilding |
Bravo leny 600 is the norm every place els it makes me sick to see a pile of cranks at LEAF with the rod's bent in a vice so no one can re use them then they are sent out local and sold for scrap some less than 300 hr. because of the 5 year rule you send a motor to them they don't tell you they wont rebuild it if it has 5 years on it till it is on the bench then they say they will send it back to you with a huge bill for the tear down. I took that course 3 times mal do not archive
aerocontrols(at)clearwave Guest
Posted: Mon Oct 30, 2006 9:32 am Post subject: need info on 582 rebuilding |
Hi All,
If you look at the Rotax Parts manual, the crankshaft for the Mod 90 and the
Mod 99 are identical. There is no difference between the two egines as far
as the crankshaft is concerned. The ear;ly Mod 90 had a crankshaft that had
smaller large end rod pins and bearings , but that was discontinued a long
time ago.
One of the reasons for not selling crankshaft parts seperately is " There
are excillent crankshaft rebuilders and there crappy crankshaft rebuilders
out there". It would be impossible for Rotax to seperate out to whom they
sell the parts. As this is aviation, if a crankshaft fails, rebuilt or
new, and there is an injury resulting from that particular failure, the
lawyers come out in drives. By simply not selling the parts they limit
their liability.
Just my personal two cents
Bob Robertson
akflyer Guest
Posted: Mon Oct 30, 2006 9:46 am Post subject: Re: need info on 582 rebuilding |
Bob thanks for the honest reply. Meens alot coming from "the guy". It kinda drives home the point I have been trying to make all along... it is a lawyer based number....and you are right on in that not just anyone should be trusted to re-build the crank.
propellerdesign(at)tele2. Guest
Posted: Mon Oct 30, 2006 11:46 am Post subject: need info on 582 rebuilding |
I think the SOLO engine that is used in many German self-launched gliders have a TBO of 400 H.
but they use the engine 5-10 min per flight..
Jan
