smokey_bear_40220(at)yaho Guest
Posted: Thu Nov 02, 2006 9:59 am Post subject: radio problem |
Kirk/Noel,
Noel! Good shot. This is what I was thinking on my
origional post too. Try the external antenna away
from the aircraft to see if it works. Then with the
radio in the same place, move the antenna (2 people
reqd) toward the plane and see if it stops. If so,
Noel is right. As he said, install a well grounded
seperate antenna.
Maybe after all else is installed and properly
grounded the radio will work again on the origional
antenna.
If not, next guess?
Kurt S.
| Quote: | My guess is there has been a piece of something
metal, not grounded about
18-20" long in your cockpit that is acting as a
parasitic element and
causing a high SWR on your antenna. If you can find
that ( probably wire
but could be something like a windshield support )
ground it. Circuits in
your radio are protecting your output transistors by
shutting the radio
down. you could try an external antenna... just
make sure the base of the antenna is well grounded.
Get your email and see which of your friends are online - Right on the New Yahoo.com
(http://www.yahoo.com/preview)
Float Flyr
Posted: Thu Nov 02, 2006 10:31 am Post subject: radio problem |
No the transponder and encoder are both grounded to the frame of the airplane.
Something in the plane is causing your outgoing transmission to be reflected back into your antenna so the transmitter works harder to put out a signal. Another circuit in your radio monitors how hard the transmitter section is working. It tells the transmitter it's working too hard and and may die if it continues to work too hard.....your transmitter shuts down (transmitters usually do what they are told).
You have to find out how the signal is getting back into the output circuit. There are basically two ways.
1. Something in your plane is resonating with your out going signal and reflecting it back into the antenna effectively creating an RF dam in your antenna and just like a water dam it causes pressure to build up behind the dam ( antenna ) In this case the pressure causes the finals of your transmitter to work harder and heat up to the point where protection circuits shut it down. The disconnected wires of your transponder coiled up under your dash could be the cause. If they are, the problem will disappear as soon as the wires are installed and trimmed to length.
2. Radio Frequency waves (RF) some how is being reflected by something in your cockpit and is able to penetrate the circuits of your radio. this is known as RF feed back. Some times you will hear a squeal as the feed back starts to gain in intensity. Radios are designed to be protected from RF feedback but sometimes bonding wires between circuit boards do get broken and problems with RF feed back arise. If you try a remote ( external ) antenna more than 3' from your radio and the problem goes away RF feed back may have been your problem and an external antenna the easiest fix.
Noel
Best of luck!
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
kirkhull(at)kc.rr.com Guest
Posted: Thu Nov 02, 2006 10:56 am Post subject: radio problem |
THANKS I HAVE SOME THINGS TO TRY
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Noel Loveys
Sent: Thursday, November 02, 2006 12:31 PM
Subject: RE: radio problem
Noel
Best of luck!
temco(at)telusplanet.net Guest
Posted: Thu Nov 02, 2006 1:35 pm Post subject: radio problem |
Kirk
Assuming that you have eliminated your antenna as the cause. Have you done an antenna VSWR from in the acrft using your problem radio?? Do this --- wrap the entire radio in normal household aluminum and ground the whole package and see if it still fails. You can push the press to talk through the foil wrap. Make sure that the entire handheld is wrapped and tightly twisted at the antenna cable and DC power lead ins. This is to prove whether the interference is airborne (radiated) or whether it is coming in on the DC power leads??? I am assuming you are hooked to your 12VDC arcft system? If it’s radiated or DC power interference ---- then shut off all other electrical and experiment by turning additional electronic/electrical systems on --- one at a time till you hit on the offending culprit
In my view there are only 3 things that can cause this problem. !. Antenna, 2. Radiated interference 3 DC power source interference.
Of course this being Halloween any of a thousand other gremlins could be in your unit.
Regards --- Ted
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of kirk hull
Sent: November 2, 2006 5:54 AM
I have been using the same antenna inside and outside the aircraft. If I hold down the transmit button outside the aircraft it will transmit then if I move the radio toward the aircraft it will stop transmitting at about 6 inches of any metal part of the plane. It works fine in the car.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Ted Palamarek
Sent: Wednesday, November 01, 2006 5:54 PM
Kirk
First thing to check is your antenna. It seems like you have an open or short and your VSWR has gone west on you. This will cause your TX final in the set to heat and turn off. If it works okay out of the plane on a different antenna then check you antenna for a short or open with a VOM
Hope this helps
Ted
Sent: November 1, 2006 3:43 PM
Subject: radio problem
I have a strange radio problem. I am using an Icom A4 it works great out of the airplane but will only transmit for about 5 sec when it is within 6 inches of any metal part of the airplane.
It use to work fine in the plane. Many changes have been made to the plane but I have no idea what is causing the problem. Any Ideas? [/b]http://www.matronics.com/Navigator?Kitfox-List01234567890123456789 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 1 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 2
Posted: Thu Nov 02, 2006 7:31 pm Post subject: radio problem |
I am using only the radio with the antenna it came with. No external power and nothing in the plane is turned on / engine off and master off
Sent: Thursday, November 02, 2006 3:34 PM
Kirk
Regards --- Ted
Kirk
Hope this helps
Ted
It use to work fine in the plane. Many changes have been made to the plane but I have no idea what is causing the problem. Any Ideas? [/b]http://www.matronics.com/Navigator?Kitfox-List01[/b] [/quote]2345
Posted: Thu Nov 02, 2006 8:13 pm Post subject: radio problem |
Kirk
Do I understand you correctly in that you are inside the airplane trying to transmit with the rubber duck antenna that came with the ICOM when the problem occurred??? If that is the case, the metal frame and other metal components may be acting as a screen or reradiating and causing a high VSWR and shutting down the TX power amplifier. If the above is true, you need to use and external antenna fed with a coax to avoid that situation. This way you put the RF field outside the metal structure of the aircraft.
I am a Ham Radio operator and operate my 2 meter rig out of my stucco garage. Of course being stucco there is mesh wire surrounding the garage (somewhat akin to the metal aircraft fuselage) and I have found that the placement of the antenna in the garage greatly affects the RF power out and the VSWR. The 2 meter frequency is just a little higher than the air to ground band.
Ted
Sent: November 2, 2006 8:31 PM
Michel
Posted: Sat Nov 04, 2006 12:17 am Post subject: radio problem |
On Nov 4, 2006, at 1:46 AM, Noel Loveys wrote:
| Quote: | Funny thing about compasses.... They are the first instrument your
plane
should have ...... And the last one you will ever look at.
That is true, Noel.
I also have problems to understand how a radio can disturb a compass,
just as I have a problem to understand how a GPS can disturb a VHF
radio. But I am old enough to know that 'impossible' is a word that
doesn't exist and I follow the tread with attention.
Michel
_________________ Kitfox 3 - Jabiru 2200 |
Float Flyr
Posted: Sat Nov 04, 2006 5:23 am Post subject: radio problem |
It's not so much the radio as the steel case it's in. Other things that can
happen is one of those magnetic screwdriver bits get left inside the case,
right under your compass.
As for the GPS RFI... That one I've seen on an early GPS. The GPS receiver
is actually three beasts in one. It's a sensitive micro wave radio receiver
with all the problems associated with high/multiple IF frequencies. It's an
astoundingly accurate timer ( 1 step away from caesium ) and it's a mini
computer and we all know how RF noisy computers are! You put something as
potentially noisy as that close to the IF circuits of your com and you will
get noise especially on the earlier models of GPS.
If you really want to see noise try placing an FM marine radio any where
close to a depth sounder! Their amplitude of the "Ping" is so high it's
almost impossible to filter. Larger ships put the actual sounder/transducer
in a remote location and only have a display routed to the helm.
As you say nothing is impossible. I remember twenty years ago telling a
friend about hams sending colour pictures all around the world... He said
so. My reply was that it was done through a 1KHZ window. That put a
different wheel on the cart. I can still remember him saying that's
impossible.
Noel
[quote] --
Kitfox III-A
Michel
Posted: Sat Nov 04, 2006 7:57 am Post subject: radio problem |
On Nov 4, 2006, at 2:23 PM, Noel Loveys wrote:
| Quote: | It's not so much the radio as the steel case it's in.
Yes, that is more understandable, Noel.
| Quote: | If you really want to see noise try placing an FM marine radio any
where
Er ... my marine VHF radio and depth sounder are no more than a foot
apart and I haven't noticed anything. But then, I am talking about the
receiver, not the transducer that is at the lowest point of the hull.
| Quote: | I remember twenty years ago telling a friend about hams sending colour
Slow-scan TV? Few people know all the weird things hams are doing, like
moon bouncing and meteor scatters ...
My only RFI, when sailing, was when I used the ham radio on the 20
meters band, with 100 Watts output, which resulted in my GPS and
Autohelm autopilot jamming. I use the isolated backstay as a long wire
antenna.
Michel
Posted: Sat Nov 04, 2006 9:42 pm Post subject: radio problem |
--- Michel Verheughe <michel(at)online.no> wrote:
| Quote: | Slow-scan TV? Few people know all the weird things
If I remember correctly, NASA borrowed slow scan from
the Ham guys, who invented it. NASA stayed with it
until the digital age for all their space pics. But
slow scan, like KitFox's and our "improvements", are
home brew. Many new ideas also come from model
builders.
We are the leaders, not the followers.
Kurt S.
Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
Posted: Sun Nov 05, 2006 2:31 pm Post subject: radio problem |
Yes and don't forget many of the engineers are also Hams so they
probably just transferred their hobby ideas into their work.
Hey, do you think there's a market for micro air cargo carriers? I can
see it now, Kitfoxes flying little packages to remote customers.
Rex
Colorado
kurt schrader wrote:
builders.
Kurt S.
_________________ Rex
N740GP - M2/582
Colorado |
Posted: Sun Nov 05, 2006 9:15 pm Post subject: radio problem |
Cross fertilization is one of the main benefits of
this list. That is how I ended up with a boat compass
and starter switch on my Fox. The boat compass
adjusted out the bad magnetism of the panel area, and
the boat starter switch has a "push to prime" function
making that a one hand operation. Learned it
here.....
I grew up with a 2 meter home made antenna on the roof
(as well as a few other bands) of a home made house.
My father taught me to "git-er-done".
| Quote: | From this list I learned things that made my Fox
better and safer. I truely believe people here have
saved lives thru prevention of costly mistakes and
honest sharing of lessons learned.
We are dreamers and sometimes get off track, but it
all seems to educate us for the better. Like Lowell,
I try to read everything and I learn. I may not have
the same engine, raido, etc, but a good idea often
comes from different sources.
We just need to keep it civil and real.
Starting with this subject "radio problem", a number
of well, and sometimes self educated people will toss
around ideas and get to the right answer eventually.
But lets try not to confuse the answer.
I remember Don S. and his surging engine problem
costing him a bunch in time, money and frustration.
If we could have been there and seen it happen just
once, many of us would have known it was the clutch
right off and saved Don a bunch. For most people this
list does make the save. Don S. is one of the hero's
in our favor, even if we didn't get it correct right
off for him, he has been there for us.
As with hangar talk, sometimes I have to walk away,
but I am right back here almost every day to learn...
Working for UPS, I used to fly Louisville, Omaha,
Cedar rapids, Louisville flights. A Cessna 4xx would
race us to Cedar Rapids every night with half a dozen
boxes for us to haul out. Sometimes it would get down
to only 2 boxes. Eventually the 4xx was canceled, but
it showed that there was still business for the little
planes too.
UPS started as West Coast boys on bikes. Now it hauls
6% of the US GNP. Certainly "Flying FoxCars" isn't
beyond reality.
Kurt S. S-5 (my other plane)
--- GypsyBeeInnkeepers <hefferans(at)gmail.com> wrote:
| Quote: | Yes and don't forget many of the engineers are also
Hams so they
their work.
remote customers.
Rex
Colorado
