MichaelGibbs(at)cox.net Guest
Posted: Fri Nov 24, 2006 9:28 am Post subject: Tri gear or Tail dragger |
Dave sez:
| Quote: | ...we all know is that taildragger configuration over all can handle
rougher ground...
It is a common perception but no, we don't all "know" that. Many
tricycle gear airplanes have rather lightweight nose wheels, the
Kitfox included, but there are plenty of very rugged nose wheels on
airplanes designed for rough-field use. They're on a different
scale, but the Lockheed C-130 and the AVIOCAR C-212 come to mind,
both of which are tricycle gear airplanes specifically designed for
rough fields.
That said, Phil Laker likes to tell the story of his trip to Alaska
with a flock of other Kitfoxes. His nose-wheeled Vixen landed on
every unimproved strip the others did with no problems.
Mike G.
N728KF
Posted: Fri Nov 24, 2006 9:29 am Post subject: Tri gear or Tail dragger |
Ron sez:
| Quote: | I've had the nosewheel fall of the Avid while warming the
motor....Found the taildraggers envelope for punishment to be a
little smaller than expected on my Kitfox.
I think a quick search of the Kitfox archives will produce a plethora
of tail wheel spring failures. Nose wheel and tail wheel failures do
not indicate an inherent superiority to one design or the other,
simply that the original structure was not up to the intended task.
| Quote: | I do feel a little silly when I taxi the tricycle Avid, and cool in
the TD Kitfox.
This comes back to what I said about having nothing to prove. I
think it's cool to just do the pilot-thang but then, I've never been
an authority on what's "cool".
Mike G.
N728KF
rick(at)rickdaniels.com Guest
Posted: Fri Nov 24, 2006 9:42 am Post subject: Tri gear or Tail dragger |
Over the last many days (perhaps too many) several comments have been made
about the ability of a taildragger to go places where a tricycle cannot. I
wish someone would describe such a place without using a situation of pilot
error to endorse or condemn a particular configuration. I have no experience
in a "Kitfox" but I am in the process of acquiring a "Kitfox" so the
description of such a place (as it applies to Kitfox only) would be very
valuable to me. Please do not respond with situations of pilot error.
Doesn't it really boil down to pilot competence?
7suds(at)Chartermi.net Guest
Posted: Fri Nov 24, 2006 1:14 pm Post subject: Tri gear or Tail dragger |
Not trying to get in the middle of anything but I feel one important
difference between the tail and nose wheel application is their maingear
location in reference to CG, noses being aft tend to straighten out a crab
on landing and tails being forward tend to amplify it lending itself more
vulnerable to a ground loop. With that said I fly a tailwheel, don't ask me
why, I just like them. I leave you all to your preferences and reasons as
well but let's not let our preferences blind us to the unique tendencies of
each, either good or bad, I think what is most important is that we know our
planes, thier limitations and how to fly them no matter where the wheels are
(even if they are in the garage for you float fliers) : )
Lloyd
*Happiness depends on happenings but joy depends on Christ*
lcfitt(at)sbcglobal.net Guest
Posted: Fri Nov 24, 2006 1:15 pm Post subject: Tri gear or Tail dragger |
Michael,
Anytime when I am asked about airplane choices, my first answer is a
question - "What will it's mission be?"
I agree that failures of the tailwheel spring has largely outnumbered the
failures of the nose gear. Without getting into the relative numbers of
tailwheel vs. nose wheel Kitfoxes and statictics, I am aware personally of a
tailwheel failure that bent the lower tubing on the rudder requiring the
removel of the fabric, straightening of the tubing and recovering. I
suspect that is about the most you would expect of this type of failure.
Actually the airplane remained airworthy and was flyable. Getting out and
home from wherever it would happen would be possible with a simple skid made
from what is available or better yet a spare spring in the misc. bag.
On the other hand I doubt a nose wheel failure would be as simple and
undoubtedly if it happened in a remote area, I suspect a remote fix would be
necessary or maybe a trailering out if possible and a much more intensive
repair depending on extent of damage which could range from a prop
replacement to cowl, engine, engine mount or fuselage fixes. Also consider
engine out sutuations where the landing site might be far from ideal.
I remember this post from Darin a bit ago and it pretty much expains what I
am trying to say.
"The reason I flew my Model III as a tailwheel and will fly my Series 7 in
tailwheel configuration was confirmed by an incident my buddy had about a
month ago while landing at a realatively benign strip in the Idaho
backcountry...he was in his 182.
In short, he went into this strip (which he had been into numerous times
before) to camp with some friends and do some fishing. On Sunday they got
up to fly home and decided to walk the strip once before starting the
takeoff roll. The reason for the walk was to pickout all major gopher
holes. They made a thourough inspection and marked all major holes then
began their taxi to the downwind side of the strip. During this taxi, a
hole that was not seen in the previous inspection swallowed his nose wheel
and he had a pretty major prop strike! His 182 is still in the A&P's hanger
and is going through a complete teardown (he is consequently considering a
full rebuild to 0-time the engine) and while the insurance is covering a
major part of it, it is still a major cost to him in dollars and lost flying
time."
I believe amid the opinions, there are some things that could come close to
being considered facts. And the relative difficulty one can get themsleves
into with that third wheel is real. Scuffed wingtips or a bent rudder is
minor compared...
Lowell
Lynn Matteson
Posted: Fri Nov 24, 2006 1:44 pm Post subject: Tri gear or Tail dragger |
I had a tailspring break, and was lucky enough to have had a spare
spring at home. Since that incident, I bought the 3-leaf spring from
John McBean, which incorporates 2 main leaves, and a helper. I'm not
sure what the odds are against both of these 2 main leaves breaking at
the same time, but I'll bet it's in the millions-to-one. I'd rather
have the "spare" spring bolted in place and preventing me from having
to deal with the possible damage that could be caused from the one and
only main spring breaking, than to just carry a spare leaf in the misc.
bag...it is still weight, so why not put it to use if you're going to
carry it? Granted, its weight is better suited in the bag, than on the
tail, but what's an extra 1-1/2 lbs or so, gonna matter, even if it is
back there?
Lynn
On Friday, November 24, 2006, at 04:15 PM, Lowell Fitt wrote:
(snip)
| Quote: | Getting out and home from wherever it would happen would be possible
with a simple skid made from what is available or better yet a spare
(snip)
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Fri Nov 24, 2006 1:47 pm Post subject: Tri gear or Tail dragger |
Installation of VERY LARGE tundra tires is one thing that I know of that can
be done with a taildragger but is limited on a nose wheel, does not make it
better, just different.
Lloyd
Float Flyr
Posted: Fri Nov 24, 2006 8:02 pm Post subject: Tri gear or Tail dragger |
Nose wheel airplanes should have a degree or so of toe in to help correct
any sideways slip and the conventional gear plane should have a degree or so
of toe out for the same reason. Tire loss to the change of toe in both
aircraft should be minimal... Not often we take out pride and joys for a
hour ride without leaving the ground.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Sat Nov 25, 2006 11:45 am Post subject: Tri gear or Tail dragger |
Lowell sez:
| Quote: | During this taxi, a hole that was not seen in the previous
inspection swallowed his nose wheel and he had a pretty major prop
strike!
Yes, I remember that story, Lowell. It isn't hard to imagine a hole
swallowing the main gear of a tail wheeled Kitfox, either. That kind
of situation could cause the fuselage to drop enough to cause a prop
strike. If the speed was high enough, it could easily cause the nose
to hit or cause the plane to pivot around the trapped wheel.
Each design has advantages and disadvantages and there are certainly
scenarios that would incapacitate any airplane. The story you
related underscores the notion that even when we do everything right,
things can still go wrong.
Mike G.
N728KF
