Z8 Ground Power test switch
Goto page Previous  1, 2
PostPosted: Mon Oct 11, 2010 1:09 pm    Post subject: Re: Z8 Ground Power test switch Reply with quote
http://eepa2a.bay.livefilestore.com/y1plAbE8KEJcAHS_99-BEHNUEuTebEghFVpbGTGXcDSdcGIgz3wNjVeCrStKgWRL1tO4_KOaV8-Js_dlVyMBgBn_admIrw7c2-d/z8_188-a.pdf?download&psid=1
John,
Above is a link to a pdf. I know that it is not exactly what you want. But the main thing that I wanted to do was to eliminate the parallel circuit around the OV circuit breaker which would prevent it from tripping. I am not saying to use this circuit. Just look at how the ground power contactor is wired and make sure that you do not connect another wire from the bottom of the coil through a switch to ground, in effect bypassing the circuit breaker.
Joe
Joe Gores
jonlaury
PostPosted: Mon Oct 11, 2010 5:13 pm    Post subject: Re: Z8 Ground Power test switch Reply with quote
Joe,
Thanks for the PDF. I understand about not building parallel circuits bypassing the OVP now. And I decided to use a separate contactor for the #2 Alternator aftter all, so I feel a little like the guy who yells "FIRE!" in the theater. Embarassed
Best,
John
Page 2 of 2
