KITFOXPILOT(at)msn.com Guest
Posted: Fri Jan 13, 2006 3:46 pm Post subject: Radio Question? |
Had a small problem with my #1 radio today and need help! this is what happened! powered up the plane, turned on avionics switch then number one radio! I was able to transmit no problem but was unable to receive! I switched to my #2 radio no problem. There was a lot of moisture in the air and don't know if maybe the contacts were fouled. any help?
Ray
temco(at)telusplanet.net Guest
Posted: Fri Jan 13, 2006 4:52 pm Post subject: Radio Question? |
Ray
The first thing you want to try is to find out whether the receiver is dead
or not. Adjust the squelch so that you should hear ambient noise if no noise
is heard then you possibly have a receiver problem. Don't know what system
you have so it is difficult to suggest how to check out the switching
between system #1 and #2. Provide some more info on what type of equipment
you have and someone will be able to help
Ted Palamarek
Edmonton Ab
Subject: Radio Question?
Ray
Posted: Fri Jan 13, 2006 7:50 pm Post subject: Radio Question? |
Thanks for your reply, I have two small terra radios that fit side by side! they have the digital numbers.
Ray
