EXP 2 Bus workaround - Master Solenoid Failure
PostPosted: Sat Oct 26, 2013 7:25 pm    Post subject: EXP 2 Bus workaround - Master Solenoid Failure Reply with quote
At 10:15 PM 10/26/2013, you wrote:
<nuckolls.bob(at)aeroelectric.com>
At 08:47 PM 10/26/2013, you wrote:
>I really enjoy this what-if stuff, so here goes...
>I'm referring to Bob's drawing sent out yesterday afternoon,
>Z-08_Full.pdf. It appears that people are touching on this issue
>but I have not seen it clearly stated.
Actually, there IS a compelling reason to move the
starter button source to the MP-Bus . . .
E-bus and Main bus on the EXP-Bus assembly have
fixed numbers of protected load-taps. Moving the
starter control to the MP-Bus frees up a load-tap
on the EXP-Bus.
But this still doesn't help you use the starter
in-flight with a contator crapped . . . you may be
able to energize the starter contactor but because
the battery contactor is open, there's no FAT wire
power to the contactor.
