Posted: Mon Oct 28, 2013 3:51 am Post subject: Oil and collant radiators |
The manual shows an arrangement with the oil rad behind the coolant rad.
I seem to recall that the optimum cooling was an arrangement with the coolant rad above the oil rad such that the oil rad dint receive already heated air. Is this correct and if so where do I find the pics.
Will
Posted: Mon Oct 28, 2013 5:02 am Post subject: Oil and collant radiators |
Hi! Will,
Since my oil never gets to a reasonable temperature anyway ....... ! The general plan is to have the oil cooler set slightly (about 1.5 inches lower that the water cooling Rad. Also have plans to plug the gap below both radiators and the bottom of the cowl. When I have time a friend gave me a thermostat oil controller to elevate the oil temperature but I need to prove the oil temperature sensor before I “monkey” with the system. I have a much modified cooling air intake and also an intake air flap to direct more cold air to the radiator on a delayed departure situation.
Frans has a wealth of info. on this subject and he may share some of it with you but we all need to know what Europa and what engine have you ?
Bob Harrison G-PTAG
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of William Daniell
Sent: 28 October 2013 11:51
Subject: Oil and collant radiators
Will | Quote: | | http://www.matronics.com/Navigator?Europa-List | 0123456789
Posted: Mon Oct 28, 2013 5:52 am Post subject: Oil and collant radiators |
Graham
Thanks that pretty much answers my question for now as I am in the process of building the ducting
However further information would be gratefully received especially with respect to ducting and airflow. I figure that once it’s all set up it’s much easier to deal with a cool running engine than a hot running engine.
I have a tri.
The engine part is a little more complex. My engine is a turbo 912 - a Colombian adaptation which originated before the 914 came out to cope with the high altitudes. This has a very similar footprint to a 914. I normally limit the MAP to 33”. I have one in my ICP Savannah and it works extremely well and it has never overheated but this aircraft has a HUGE radiator and lots of space under the cowl.
As far as the heat generation is concerned I suspect it is somewhere between a 912S and a 914. I have the standard Europa 914 kit components inc oil and coolant rad.
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Bob Harrison
Sent: Monday, October 28, 2013 08:00
Subject: RE: Oil and collant radiators
Hi! Will,
Bob Harrison G-PTAG
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of William Daniell
Will012345678901234567
h&jeuropa
Posted: Tue Oct 29, 2013 6:53 pm Post subject: Oil and collant radiators |
Thats exactly what I needed
Will
