Landing gear towers modification
gengrumpy
PostPosted: Wed Oct 30, 2013 9:50 am    Post subject: Landing gear towers modification Reply with quote
I am now to the point where I plan to cut out the solid portion between the bottom and middle lightning holes to provide better access inside the towers. I plan to fab a cover plate to go over this area using plate nuts and ss #8 screws.
If you have opened this area up, or if you have done any engineering analysis of this mod (Van�s has not done any analysis) please let me hear from you, both good and bad.
Thanks - grumpy
gengrumpy(at)aol.com
