glasair III fuel system
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
rolahug(at)gmail.com
PostPosted: Sat Nov 09, 2013 1:36 pm    Post subject: glasair III fuel system Reply with quote
My ship, #3084, was built in 1989 -1990. Does anyone have a fuel
system description/schematic that would guide me? I have a fuel leak
from the aft fuselage vent, and the smell of fuel in the cabin.
Robert
N957DJ
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
gossend(at)gmail.com
PostPosted: Sat Nov 09, 2013 3:27 pm    Post subject: glasair III fuel system Reply with quote
Robert, does that happen after filling up the tank(s), or on every flight, even at 50% or below capacity? I may be able to help in both cases, but they are different.
Dick Gossen
N90GG
Flying my beautiful girl since 1990
Robert
N957DJ
PostPosted: Sat Nov 09, 2013 4:58 pm    Post subject: glasair III fuel system Reply with quote
Hello Dick,
I haven't had the mains full up for years, but didrecently fill to the
brim the header tank just before the cabin smell started happening.
Since my email to the list, my mechanic hooked an air compressor to
the fuselage vent tubes. After blowing out the lines,he weighted the
aft fuselage on the ground, lifting the nose up at a high angle. No
sign of a leaking vent tube. I then flew the aircraft, and smelled
nothing. When I landed, there was no leak at the fuselage vent.
Happy, for sure, but suspicious I haven't really solved the problem.
Any thoughts you have would be greatly appreciated.
Robert
Dick Gossen
N90GG
> Thanks,
> Robert
> N957DJ
PostPosted: Sat Nov 09, 2013 7:00 pm    Post subject: glasair III fuel system Reply with quote
OK....I just collaborated with my fellow Glasair friend, Bob Buckthal. I have a Glasair III, Bob has a Glasair IIS. We agree that your problem may be a non-problem. The way your airplane is plumbed, there are three vents going to the vent manifold on the belly. Each main wing tank is vented to that manifold, and the 'header tank' (actually AUX tank) is vented there as well. The purpose of the vents is to allow air to flow into the tank(s) as fuel is consumed by the engine. If any of the three vents gets fuel in it, on the other hand, the fuel will drain down and exit one or both of the belly vent tubes, then run back to the tail, where it will be sucked into the fuselage cavity through the opening where the elevator pushrod exits. You'll smell it immediately.
To restate: The belly vent manifold has two exit tubes (in case one gets blocked) and is connected internally by three lines: one from each outer wing, and one from the upper side of the AUX tank near the top. If you fill the AUX "to the brim", it will dump the first 1/2 inch or so of fuel overboard through the belly vent. It will be smelly. Don't smoke!
Bob, anything to add?
DG
N90GG
On Nov 9, 2013, at 6:58 PM, Robert Hunter <rolahug(at)gmail.com> wrote:
Hello Dick,
Robert
> Dick Gossen
> N90GG
>> Thanks,
>> Robert
>> N957DJ
rbuckthal(at)gmail.com
PostPosted: Sat Nov 09, 2013 7:46 pm    Post subject: glasair III fuel system Reply with quote
At high power settings and high AOA I would get a CO alarm.  I spent a lot of time sealing  the underside of the airplane only to discover that the CO was getting in through the rudder opening.  Same thing would happen whenever fuel vented onto the belly.  Level flight was always successful at clearing the CO alarm or fuel smell.  The plans called for the aux tank vents to be on the side to the tank.  If the builder did not alter the location of the vents inside the tank the top 4 to 6 inches of the tank will not be useable due to the curvature of the top of the tank.  Any attempt to fill that space will likely go out the vent onto the belly or the ground.
Bob
N223B
On Sat, Nov 9, 2013 at 6:59 PM, Dick Gossen <gossend(at)gmail.com (gossend(at)gmail.com)> wrote:
[quote]--> Glasair-List message posted by: Dick Gossen <gossend(at)gmail.com (gossend(at)gmail.com)>
DG
N90GG
On Nov 9, 2013, at 6:58 PM, Robert Hunter <rolahug(at)gmail.com (rolahug(at)gmail.com)> wrote:
> --> Glasair-List message posted by: Robert Hunter <rolahug(at)gmail.com (rolahug(at)gmail.com)>
> Hello Dick,
> Robert
> On Sat, Nov 9, 2013 at 4:26 PM, Dick Gossen <gossend(at)gmail.com (gossend(at)gmail.com)> wrote:
>> Dick Gossen
>> N90GG
>> On Nov 9, 2013, at 3:36 PM, Robert Hunter <rolahug(at)gmail.com (rolahug(at)gmail.com)> wrote:
>>> Thanks,
>>> Robert
>>> N957DJ
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
et="_blank">www.mypilotstore.com
"_blank">www.mrrace.com
le, List Admin.
" target="_blank">http://www.matronics.com/Navigator?Glasair-List
http://forums.matronics.com
PostPosted: Sun Nov 10, 2013 4:14 pm    Post subject: glasair III fuel system Reply with quote
Thank you both. I am confident that my problem was from a super full
aux tank. I flew again today to confirm that.
It will probably be, I'm sorry to say, my last flight in 957DJ. I'll
be checking out the new owner.
Robert
On Sat, Nov 9, 2013 at 8:46 PM, Robert Buckthal <rbuckthal(at)gmail.com> wrote:
Bob
N223B
> immediately.
> DG
> N90GG
> > Hello Dick,
> > Robert
> >> Dick Gossen
> >> N90GG
> >>> Thanks,
> >>> Robert
> >>> N957DJ
> ="_blank">http://www.matronics.com/contribution
> le, List Admin.
PostPosted: Sun Nov 10, 2013 7:17 pm    Post subject: glasair III fuel system Reply with quote
Sorry to hear that. Glad we could help.
Robert
> Bob
> N223B
>> immediately.
>> DG
>> N90GG
>>> Hello Dick,
>>> Robert
>>>> Dick Gossen
>>>> N90GG
>>>>> Thanks,
>>>>> Robert
>>>>> N957DJ
>> le, List Admin.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
