brake lines
carlossa52(at)gmail.com
PostPosted: Mon Nov 11, 2013 10:35 am    Post subject: brake lines Reply with quote
What have people been using for brake lines?
(Not that my project is going anywhere without wheels, but...)
Carlos
CH601-HD, plans
bryanmmartin
PostPosted: Mon Nov 11, 2013 11:30 am    Post subject: brake lines Reply with quote
I used the clear plastic tubing that came with the kit. I believe it’s nylon.
Carlos
CH601-HD, plans
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus re-drive.
Bryan Martin
do not archive.
steve.freeman(at)syntaxds
PostPosted: Mon Nov 11, 2013 11:52 am    Post subject: brake lines Reply with quote
I used the supplied nylon product. On the lines that are exposed to the
elements I ran the brake lines inside an aluminum tube. This makes for
a clean and I believe functional install. I can send pictures if you
would like.
Steve Freeman
602-228-3830
PostPosted: Mon Nov 11, 2013 12:14 pm    Post subject: brake lines Reply with quote
That you be nice, if you could
Thanks, Steve
On 11 November 2013 14:52, Steve Freeman (SDS) <steve.freeman(at)syntaxds.com (steve.freeman(at)syntaxds.com)> wrote:
[quote]--> Zenith-List message posted by: "Steve Freeman (SDS)" <steve.freeman(at)syntaxds.com (steve.freeman(at)syntaxds.com)>
would like.
Steve Freeman
gfmjr_20(at)HOTMAIL.COM
PostPosted: Mon Nov 11, 2013 1:46 pm    Post subject: brake lines Reply with quote
I used the high pressure plactic tubing and routed the rear of the landing gear legs with a 1/4 inch bit, fitted the tubing , applied a little silicon and a couple of small clamps.
George May
601XLB   --500hrs
Date: Mon, 11 Nov 2013 13:35:01 -0500
Subject: brake lines
Carlos
CH601-HD, plans
_blank>www.aeroelectric.com
/" target=_blank>www.buildersbooks.com
=_blank>www.homebuilthelp.com
=_blank>www.mypilotstore.com
ank>www.mrrace.com
=_blank>http://www.matronics.com/contribution
target=_blank>http://www.matronics.com/Navigator?Zenith-List
ttp://forums.matronics.com
bryanmmartin
PostPosted: Wed Nov 13, 2013 8:19 am    Post subject: brake lines Reply with quote
I routed the nylon tubes from the master cylinders back through the rudder cable tunnel then under the seats and out the fuselage sides through grommets under the wing just behind the landing gear spring. I drilled and tapped holes on the rear of the spring for adel clamps to hold the nylon tubes, three clamps per side. The brake cylinders are installed so the fitting is to the rear and the nylon tubes are exposed from the fuselage to the brakes. The installation is cheap, light, easy to inspect and has been trouble free for nine years and 400 flight hours.
Bryan Martin
N61BM, CH 601 XL,
Bryan Martin
do not archive.
bryanmmartin
PostPosted: Wed Nov 13, 2013 8:35 am    Post subject: brake lines Reply with quote
I didn’t use actual adel clamps to hold the brake lines to the main gear spring, I bought a box of black nylon tubing clamps. I got these either from the hard ware store or Home Depot. I have used them in several places to hold tubes and small wire bundles in place.
Bryan Martin
N61BM, CH 601 XL,
Bryan Martin
do not archive.
PostPosted: Tue Nov 19, 2013 5:09 am    Post subject: brake lines Reply with quote
Clive, thanks for the pictures.
Did you powder coat the landing gear?
Carlos
On 19 November 2013 07:15, Clive Richards <s.clive.richards(at)homecall.co.uk (s.clive.richards(at)homecall.co.uk)> wrote:
[quote] Hi Carlos Please find picture of our 601DH
         The brake lines run from pedal cylinders through lightning holes under seat & into wing.
  I suggest you fit a plate to original pedals to give sufficien leverage to hold for runup
Clive             G CBDG 618 Hrs
PostPosted: Wed Nov 20, 2013 1:38 pm    Post subject: brake lines Reply with quote
Carlos
Ray originally sent the legs to a firm for corrosion proofing and painting with 2 pack, he thinks they were nickel plated before painting. This June we replaced the Bungies, cleaned & he repainted the forks & legs etc in 2 pack
Clive
