		Mike Whisky
				 Posted: Sat Nov 16, 2013 7:52 am    Post subject: Is there more than one location to install an oil temp probe |
				Hi,
 I am thinking to install the oil temp controller from experimentalgoodies.com, I am not sure if there is a second port on the TMX-IO-540 to install an oil temp probe. I don't have my manual with me and won't be in the hangar for a couple of days so I 'd appreciate if someone could help.
 Mike
  _________________ RV-10 builder (flying)
#511 |
		Kelly McMullen
				 Posted: Sat Nov 16, 2013 12:48 pm    Post subject: Is there more than one location to install an oil temp probe |
				Yes. There are plugs at the front of the engine that are used during overhaul to clean the oil galleys. You can remove one (very carefully) with an appropriately sized allen socket.
 It is worth having the right size that you can put a 3/8s ratchet wrench on. You may have to also apply some heat with a propane torch in that area to loosen whatever sealant was used on the plug. They are difficult to get loose, and you darn sure do not want to round off the flats on the allen plug.
 On Sat, Nov 16, 2013 at 8:52 AM, Mike Whisky <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)> wrote:
   	  | Quote: | 	 		  --> RV10-List message posted by: "Mike Whisky" <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)>
  Hi,
  Mike
  RV-10 builder (flying, test phase)
  #511
  http://forums.matronics.com/viewtopic.php?p=413202#413202
  ="_blank">www.aeroelectric.com
  ooks.com" target="_blank">www.buildersbooks.com
  et="_blank">www.homebuilthelp.com
  et="_blank">www.mypilotstore.com
  "_blank">www.mrrace.com
  le, List Admin.
  - sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
