by0ung(at)brigham.net Guest
Posted: Sat Jan 14, 2006 11:10 am Post subject: kolb washout / trim |
The Kolb MkIIIc/912ULS I have has a strong tendency to turn left. The
bungee cord
does a fair job of countering that, but I'd like to effect a bit more
nominal
solution.
So, I have TWO questions:
1) I'm thinking about adding an aileron trim. Can anyone suggest
approaches to
doing that, suggest methods/materials, and maybe even details on how to do
it.
2) I've been told by at least two people, "oh, check your washout!" as if
to say
that might solve my strong-left-turning-tendency. And although I have a
very
general idea what washout is, I would have no idea about how to MEASURE it
and then, if were "wrong", how to correct it.
Any constructive comments?
-- Robert
Robert
1 st aileron trim
If the plane wants to roll to the left, it would be best to add a trim tab
to the bottom trailing edge of the right aileron I built mine one rib bay
wide, and it was made of .032 alum. The measurements was, as close as I
can remember, wide enough to rivet to the ribs on each end.. and about 3
inch from front to back there was a bend at about the 1 inch mark.
The bend was enough so that when the 1 inch side was held flat on the
workbench the end of the 2 inch side was about inch off the table top.
The 1 inch side was riveted to the bottom of the trailing edge tube and
the bottom of the ribs. With the bend pointing down. After trial fitting
the trim tab. I put a piece of masking tape across the front edge where the
tab touches the fabric, then I ran my fingernail over the edge and cut the
tape ( do not use a knife ) when I did the final install I put a small
bead of silicone rubber on the tab where it contacted the fabric and the
excess squeezed out where the tape was cut. I then wiped the excess off
and removed the tape for a no smear installation.. I think I had 1 rivet on
the leading edge of the tab in the ribs and 3 or 4 across the trailing edge.
After trials you may need to bend the tab more or less.
2 nd. Washout.
Washout is a twist in the wing so that the leading edge and trailing edge
are not straight in line with each other. to measure you hold a level
from the leading edge to the trailing edge of the right wing at the inboard
part of the wing. Prop up the tail until the level is level. Then
repeat on the outboard end of the wing if the level is still level
there is no washout, or washin. Kolb wings should be built straight with
no twist.. if there must be an error it is better to have the wing twisted
so the leading edge of the outboard part of the wing is lower than the
trailing edge. Some aircraft have a 2 or 3 inch twist in the wings
this causes the wing tip to be at a lower angle of attack and will stall
last, giving aileron authority through a stall now that we have done
the right wing, leave the tail where it is and check the left wing the
inboard part of the left wing should be level, if not the wing attach
fitting may have been drilled incorrectly. Then check the outboard end of
the wing. It as well should be level again if there is an error it would
be better if the leading edge was lower than the trailing edge.
The worst case is if the center of the wings were both level and one wing
had the leading edge wing tip high and the other wing leading edge wing tip
low
If you have any further questions feel free to contact me
Boyd Young
| - The Matronics Kolb-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Richard Pike
Joined: 09 Jan 2006 Posts: 1669 Location: Blountville, Tennessee
Posted: Sat Jan 14, 2006 11:54 am Post subject: kolb washout / trim |
If you make your trim tab adjustable, then you can set it to level when
you have a passenger, and down when you are solo, and have no stick
pressure either way. Here's how I did it, crude, but works good.
http://www.bcchapel.org/pages/0003/pg6.htm
Richard Pike
MKIII N420P (420ldPoops)
boyd wrote:
bungee cord
nominal
solution.
approaches to
it.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
