M14P Oil System Temp Reading Location
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
FatBoy
PostPosted: Sun Nov 24, 2013 9:17 am    Post subject: M14P Oil System Temp Reading Location Reply with quote
Good morning --
Trying to get the recommended location for oil system temp probe(s).
Manual says: Recommended Engine Inlet temps: 122-149F
Maximum permissable engine outlet oil temp: 257F
I have a Peterson Fluid Systems tank with a probe port for the EI MVP50 monitor in the bottom half of tank, approximately 3.5 inches above the -12 oil outlet port. If I understand the oil system correctly, the next point after the oil leaves the tank is the engine driven oil pump.
Where are folks (Yaks, Moose, Radial Rocket, etc.) placing probes? More than one?
Cliff has recommended a MoCal AOT2 thermostat. Is there a location there folks are monitoring?
Also, is the cooler placed before the filter or filter before cooler?
Thanks very much for any notes / comments --
Andy Hawes
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
GeorgeCoy
PostPosted: Mon Nov 25, 2013 6:07 am    Post subject: M14P Oil System Temp Reading Location Reply with quote
Andy, The oil tank temperature measured at the tank just before the outlet
would be the same a inlet oil temperature to the engine.
The Yaks have a small tank for a probe at the external oil inlet screen.
Some of the eastern block aircraft did measure both inlet and outlet oil
temperatures. (Wilga, PZL & Zlin).
Filter before or after oil cooler has been debated often. Most Yaks where
people have installed oil filters have installed them before the oil cooler.
George
FatBoy
PostPosted: Mon Nov 25, 2013 9:13 am    Post subject: M14P Oil System Temp Reading Location Reply with quote
Thanks George
George
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
