Trying to finish RV-6
gra9933(at)bellsouth.net
PostPosted: Sat Jan 14, 2006 11:24 am    Post subject: Trying to finish RV-6 Reply with quote
Everyone:
I have two problems one of you may be able to help me with.
Problem 1) I need to do the weight & balance on my RV-6 and I haven't
found a set of scales, yet. Does anyone know where I can borrow a
airplane scale in the Goldsboro, NC area?
Problem 2) I have an engine that is not running well. I have test run my
XP-360 twice, and both times it has run very rough at idle. It will quit
when I pull the throttle back below 1000 RPM. I have a constant speed
propeller, Airflow Performance fuel injection, Lightspeed Electronic
Ignition, and an impulse coupled mag on the left side. Its a brand new
engine built by Aerosport Power. When it starts, it has a puff of black
smoke and it sounds like its backfiring or something when it runs (loud
popping sounds). Runs about the same on the mag as the Lightspeed - but
fewer "popping" sounds on the Lightspeed. I am not very smart on
engines, so I'm not good at diagnosing the problem here. My going in
theory is that the Airflow Performance idle mixture adjustment is set
too rich - does this sound right for my symptoms?
Thanks if anyone can help - I sure appreciate it. I am about to deploy
to Southwest Asia for a few months, so I would really like to get this
airplane flying before I go!!
Jordan Grant
N198G, RV-6
Steve Glasgow
PostPosted: Sat Jan 14, 2006 11:56 am    Post subject: Trying to finish RV-6 Reply with quote
I can find some scales if you want to drive to Lake Norman, north of Charlotte.
Sorry can't help on the engine, I'm carburated.
Steve Glasgow-Cappy
N123SG RV-8
Cappy's Toy
704-362-0005
704-281-7884
Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG
bburril(at)carolina.rr.co
PostPosted: Sun Jan 15, 2006 6:56 am    Post subject: Trying to finish RV-6 Reply with quote
Jordan,it sounds like a wring problem.Have you double ckecked your firing
order and the timing? Ben
