Garmin G3X Autopliot Auto Trim with Big Trim Motor
PostPosted: Sat Nov 23, 2013 9:13 am    Post subject: Garmin G3X Autopliot Auto Trim with Big Trim Motor Reply with quote
At 09:50 AM 11/23/2013, you wrote:
Tim,
That's not quite the answer I was looking for. But rather than try
to figure out what's happening via text in emails, let's start w/
whatever diagrams you have. Then we can drill deeper as necessary.
Standing by until you post the link ...
The entire g3x manual is available at
http://tinyurl.com/l88273j
PostPosted: Sat Nov 23, 2013 4:23 pm    Post subject: Garmin G3X Autopliot Auto Trim with Big Trim Motor Reply with quote
At 02:47 PM 11/23/2013, you wrote:
<tim(at)aircraftersllc.com>
let's try this. HEre's a link:
http://www.aircraftersllc.com/docs/Garmin%20Suggestion.png
Hmmmm . . . you need to know the nature of Gramin's
PWM philosophy.
NORMALLY . . . pwm means applying a consistent voltage
to a motor where duty cycle is adjusted to move the
motor at any speed from zero to max.
But in systems like the Beechjet (BIG motors with
brakes on them) one cannot get slow, steady motion
from the motor by fooling it into believing that
the supply voltage has dropped. These systems accomplish
precise control by PULSING the motor at full voltage
with varying lengths of time.
I did a study on Beechjets to characterize pitch
trim performance at Mach cruise to see how short
the pulses could be and STILL move the trim system
but not so long as to be noticed by passengers and
crew in the seat of their pants.
Turns out 133 mS was the 'magic' number. If you're
going to control your high current motor through
relays, then you are most definitely limited to
a full-voltage pulsed mode as opposed to the variable
duty cycle so-motion mode.
Question: Does the Garmin system really work in the
PWM mode or PULSED mode?
This can be done with relays . . . having very fast
response times. This might be a case for installing
the zener-based coil suppression. But the ideal
buffer will be solid state. This raises the questions
I cited earlier about prophylactic measures against
unintended motion.
PostPosted: Wed Nov 27, 2013 9:27 am    Post subject: Garmin G3X Autopliot Auto Trim with Big Trim Motor Reply with quote
Sure. Will this project include a wheel-master disconnect
switch?
PostPosted: Wed Dec 04, 2013 2:42 pm    Post subject: Garmin G3X Autopliot Auto Trim with Big Trim Motor Reply with quote
Any thoughts on using transistors in this setup instead of relays?
Tim Farrell
Aircrafters
831-722-9141
Tim, I thought I had responded to this. Are you
still interested in a solid state 'relay deck' for
this application?
Do you plan to have a "stick master disconnect"
switch?
