cookflys
Posted: Fri Nov 29, 2013 4:56 pm Post subject: GSC prop |
I have a GSC 3 bladed prop that I can only get 10 degrees pitch out of because of the center bolt slot .
Has anyone else had this problem ?
How much if any can I elongate the slot?
It goes on a 582 and reaches 6600 RPMs with more throttle to go so I need to have more pich.
_________________ Charles Cook
Model II 582
#363 |
Float Flyr
Posted: Fri Nov 29, 2013 8:10 pm Post subject: GSC prop |
I take it you have calibrated your tachometer. The westach units are somewhat less than useless. I had that problem... The Westach read just about 20% high across the board. Imagine taking off (at)4200 rpm with a 582 in a model III on floats!
Noel
Sent from Yahoo Mail on Android From: Charles Cook <cookflys(at)yahoo.com>;
To: kitfox-list(at)matronics.com <kitfox-list(at)matronics.com>;
Subject: GSC prop
Sent: Sat, Nov 30, 2013 12:56:17 AM
--> Kitfox-List message posted by: Charles Cook <[url=javascript:return]cookflys(at)yahoo.com[/url]>
<-> htsp; -ist Kitfox-List" target=_blank >http://www.matronics.com/Navigator?Kitfox-Lis> http://forums=====================
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
