		airmanv2
  Joined: 01 Dec 2013 Posts: 49 Location: France - Normandy
				 Posted: Tue Dec 03, 2013 3:41 am    Post subject: CJ6 Primer left /Right and manual pomp |
				Hi every Body,
 I'm a (the) new french owner of a Uk reg. CJ6A based LFAO.
 I have question regarding the start up procedure.
 At his time I was told to pull 9 blades, prime 4 strokes, manual pomp 6 times.
 Pressure in the air tank at 40 Kg, propeller turn slowly and some time i do not succeed to start.
 So I pull again 9 blades, 4 strokes an 4 manual pomp again and some time its fine , some time not.
 Some time a third try and if not start I have a to low air pressure  and must refile the air tank .
 Question: is that the correct method to practice?
 Question? I saw that the primer can be turn right or left but I don't now the reason and how it must be used?
 thanks for help
 Bruno
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Fly safe |
		cjpilot710(at)aol.com Guest
				 Posted: Tue Dec 03, 2013 9:38 am    Post subject: CJ6 Primer left /Right and manual pomp |
				Bruno.
  The primer is pretty simple.  It does not matter which way it turns  when fully down, as long as it locks down.  If you have pulled it up to  prime, when you push it down, you must turn it 90 degrees (in either  direction) in order for it to close and lock.  If you do not turn it  90 degrees, the primer will let a lot of fuel flow though, and flood #9 cylinder  which at lower power settings causes the engine to run rough.  I've seen  two occasions where the valve in the bottom of the primer has screwed  up, causing the engine to run rough, thus needing to replace the primer.   (Simple job)
  Your starting procedure sound OK for the most part.  Pulling the prop  though 9 times really is only making sure you do not have a hydraulic lock  in the bottom cylinders.  Having one could (most likely WILL) cause  you to bend a connecting rod, which will lead to a engine failure.   Promise.
  I have over 2,000 hours with the M-14 and Hs6a engines in my  log.  I don't use the procedure the Chinese call for in the book,  except on a cold day.  I've found that priming 4 to 6 times,  than pumping the wobble pump until I see the fuel pressure gage rise,  is enough for the HS6.  On the M-14p all I do is pull the prop though  checking for a hydraulic lock, climb in the cockpit, prime 4 times (on a cold  day 6), hold the pre-oil switch until I get oil pressure on the gage, and hit  the starter button.  3 blades and she's running.
  On the HS6 engine you can turn the mags on first, before pushing the  starter button. (Not a good idea on the M-14p).  Some times you will get  a "kick or two" during the start.  Be prepared to pump the primer  once or twice or even three times, to try and catch it.  If you do  this, make sure you close and lock the primer after the engine is running.   (BTW you can run the engine just by pumping the primer - knowing that  has saved my ass.)
  You can "flood" (to much fuel) these engines.  If you think you have  flood one, simply during start while still pushing the start button, open the  throttle all the way.  BE READY TO CLOSE IT IF THE ENGINE STARTS!!   Doing this - leans out the mixture for a start.
  Some times the "buzz box" "Shower of Sparks" or 'Exciter" might be weak or  inop.  This can make the engine hard to start.  If you press the start  button and hear a healthy buzz up front, its mostly likely working.
  Your air pressure sounds a little low but is more than enough.  These  engines can be hand started easily.  So I don't believe 40 atmospheres is  not your problem.
  Hope this helps. Good luck.
  Jim "Pappy" Goolsby
   In a message dated 12/3/2013 6:43:01 A.M. Eastern Standard Time,  bruno.blanchard2(at)gmail.com writes:
   	  | Quote: | 	 		  -->    Yak-List message posted by: "airmanv2"    <bruno.blanchard2(at)gmail.com>
 Hi every Body,
 thanks for    help
 Bruno
 Fly safe
 Read this topic    online    here:
 http://forums.matronics.com/viewtopic.php?p=414766#414766
		jdeuchar
				 Posted: Tue Dec 03, 2013 9:39 am    Post subject: CJ6 Primer left /Right and manual pomp |
				Hi Bruno,
 I use (when cold):
 Pull through 9 blades. This way I know if I have an issue before introducing
 fuel.
 Prime 6 shots
 Pull through 6 blades
 Prime 2 - 4 shots, leaving the primer up
 Pump until fuel pressure shows good with throttle closed.
 Throttle cracked
 Start - if it hasn't run for a long time, it will take me twice with the
 above, also prime while starting, or pumping the throttle (accelerator pump)
 works same.
 As far as primer open left or right, it doesn't matter, it is just to get it
 unlocked.
 Jeff
		airmanv2
				 Posted: Tue Dec 03, 2013 2:45 pm    Post subject: Re: CJ6 Primer left /Right and manual pomp |
				Hello Jim and Jeff, Thank you for help,
 I think i will try this WE, I ll keep you advice.
 Best,
 Bruno
		Harv
		airmanv2
				 Posted: Mon Dec 09, 2013 12:03 pm    Post subject: Re: CJ6 Primer left /Right and manual pomp |
				thanks for all your advices
 i made a mix  off all and finally succeed to start and made a marvelous flight just before the night.
 1/2 hour eating the engine with an electric fan in the hangar
 18 blades
 moving out
 9 blades
 batt + eng instr on
 primer up
 wobble pomp 6 times
 3 primers slowly
 3 blades
 3 primers slowly
 closing the drain
 wearing the chute, tightened in the seat, open Air (35 atm)
 throttle open 2 inches,
 press start, engine wanted to start , helping with throttle and primmer ....
 ..... i had forgotten the Mag. !!!
 Second try after a couple of minutes (3 blades more, 3 prime)
 And engine run after 2 blades
 YES!!!
 thank you for your help
 Bruno
