		| Author | Message |
		| asarangan(at)gmail.com Guest
				|  Posted: Wed Dec 11, 2013 8:33 pm    Post subject: Fuel tank outlet connector hose |   |
				| This is the rubber hose that clamps over the tank outlet and the
aluminum insert fitting (F09C). The ID of this hose is 1", but my tank
 outlet nipple is about 1.15". This is a very rigid and unforgiving
 hose,  so it is hard to stretch. But even if I could force it  I am
 concerned if it might put excessive clamping force on the plastic
 nipple. Or worse, it may be impossible to remove later without cutting
 the tube, and then I might risk cutting into the underlying plastic
 nipple as well.
  	  | Quote: |  	  | From the little bit I could gather from the label, this is Semperflex Multi-Purpose Mineral Oil Hose, 25 Bar max pressure (350psi). This
 rating sounds like an overkill to me.
 My guess is that the fuel pressure at this point is not going to be
 more than a couple of psi so chemical compatibility is more important
 than pressure or wall thickness. I was thinking of replacing this with
 a thinner more flexible Buna-N hose, but wanted to hear how other
 builders solved this problem.
		| Back to top |  |
		| h&jeuropa
				|  Posted: Fri Dec 13, 2013 7:21 am    Post subject: Re: Fuel tank outlet connector hose |   |
				| Andrew
 We initially used the revised fittings from Graham Singleton.  With those a larger inner diameter hose is needed.
 One of those fittings backed out of the tank.  So we made up new fittings with a lip to aid with retention.  Our tank outlets are very close to 1 1/8 inch OD.  We purchased preformed radiator hose whose ID is 1 1/8 and cut out straight sections to fit.  Seems like we had to get preformed hoses because straight hose was not available in 1 1/8 inch.  We replace these every 5 years and inspect every year.
 I'll post a drawing of the fitting in the next couple of days.  Currently having computer problems and can't print anything!
 Jim & Heather
 N241BW
		| Back to top |  |
