msm_9949(at)yahoo.com Guest
Posted: Wed Dec 11, 2013 11:26 am Post subject: What Happen to this Kifox List? |
I tried that method Ron but the rubber on those Kingfox tires is so thin, when you tighten the strap it just folds over. I got frustrated and took it to the tire store. If you haven't seen Dave's video on how to seat a tire with starter fluid and a propane torch, check it out. Sounds crazy but it works!
Marco Menezes N99KX
Kitfox II 582-90 C-Box w/clutch
Hersey, MI
Sent: Wednesday, December 11, 2013 11:44 AM
Subject: Re: What Happen to this Kifox List?
Here is a trick I learned way back for getting tires to reseat the bead: With the tire on the wheel, take a 1β or 2β wide jacking tie down strap and wrap it around the tire down its center line. Then tighten the strap by jacking it until the bead is tight to the wheel. Then put air into it through the stem. You will hear the pop when it seats tight.
I use this method on golf cart wheel changes as well as my Model 2 Fox.
Ron #336
Sent: Wednesday, December 11, 2013 10:22 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Yep. We are planted here for life, Patrick. Flying season is over for me. I had an issue this past season thhough, after mounting new Kingfox tires.,The airplane was frequently yawing to the left on touchdown resulting in a number of "excursions" into the grass (always to the left). Been thinking about why.
While swapping out the tires, I couldn't get the bead to reseat on the left one so took it to a tire store. I've since learned that they used "alot" of bead seating compound to get the job done. I've concluded that I didn't suddenly forget how to land a taildragger, rather that the main gear has likely become unbalanced due to a ton of goo slapping around in the left tire. I'll have to remove the tire again, clean it out and remount reseating the bead myself useing Dave's you-tube "explosion" method. Tried that with a trailer tire last Summer and it works pretty slick. Stay tuned!
Marco Menezes N99KX
Hersey, MI
Sent: Monday, December 9, 2013 4:56 PM
Marco, Good to hear your still here. Here in MI still?
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
[quote]www.aeroelectric.com * HomebuiltHELP [url=http://wwe
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.mypilotstore.com">www.mypilotstore.com
href="http://www.mrrace.com">www.mrrace.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
wwwlow" target="_blank" href="http://www.buildersbooks.com/">www.buildersb= * My Pilot Store [url=httplting http://forums.matronics.com[/url]===============
Posted: Wed Dec 11, 2013 11:41 am Post subject: What Happen to this Kifox List? |
Pat,
In seven years flying this airplane, I've never experienced issues that might be attributed to toe-in/out misalignment of the main gear. Plus I don't think the alignment would have changed simply because of new tires. I can detect no rubbing or binding on the left side that would cause the airplane to veer on roll-out. Also, it doesn't happen every time but frequently enough (and always to the left) so that I'm thinking it's a goo-induced imbalance. Anyway I'm gonna clear that stuff outta there and see what happens.
Marco Menezes N99KX
Hersey, MI
Sent: Wednesday, December 11, 2013 1:52 PM
Subject: Re: Kitfox-List: What Happen to this Kifox List?
Marco, Do you think that a different tire weight would cause a veering problem? It would be my guess that something is rubbing or binding that wheel or toe in or out. Glad to hear someone was successful "with exploding" tires on to a rim. I have seen video's of it, but never tried it myself.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Wed, Dec 11, 2013 at 10:44 AM, Ron L <rliebmann(at)comcast.net (rliebmann(at)comcast.net)> wrote:
Quote: | Here is a trick I learned way back for getting tires to reseat the bead: With the tire on the wheel, take a 1β or 2β wide jacking tie down strap and wrap it around the tire down its center line. Then tighten the strap by jacking it until the bead is tight to the wheel. Then put air into it through the stem. You will hear the pop when it seats tight.
Ron #336
Marco Menezes N99KX
Hersey, MI
From: Patrick Reilly <patreilly43(at)gmail.com (patreilly43(at)gmail.com)>
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
Quote: |
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
="_blank">www.homebuilthelp.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
arget="_blank">http://www.matronics.com/Navigator?Kitfox-List
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
[quote]www.homebuilthelp * Race Consulting http://www.matronics.com/contributiottp://www.matronics.com/Navigator?Kitfox-List">http://www.matronics.com/Navet="_blank" href="http://forums.matronics.com/">http://forums.matronics=================
