		jdm(at)wideworld.net Guest
				 Posted: Wed Jun 21, 2006 8:42 am    Post subject: AZUSA Breaks |
				I need to replace the brakes assembly on my original Firestar because I am
 less than satisfied with the 15 year old brakes despite tinkering with them.
 I'm looking at the AZUSA 5" brakes and wheels.  Does anyone have any
 experience with theses?
 I read comments in the past about MATCO hydraulic break for the Mark III,
 etc, but I think this would be over kill on a Firestar.
 Any other suggestions?
 Thanks.
 John Murr
		HShack(at)aol.com Guest
				 Posted: Wed Jun 21, 2006 11:48 am    Post subject: AZUSA Breaks |
				In a message dated 6/21/2006 12:43:53 PM Eastern Standard Time,
 jdm(at)wideworld.net writes:
 Matco's are not overkill on a Firestar.
 Howard Shackleford
 FS II
 SC
		planecrazzzy Guest
				 Posted: Wed Jun 21, 2006 12:34 pm    Post subject: Re: AZUSA Breaks |
				I have 5" azusa brakes on my Firestar...
  http://www.geocities.com/planecrazzzy/LSXIII.html
  They fit with the "stock" wheels from Kolb
     They do the job...
 Gotta Fly...
 Mike in MN
		MKIIIX040
  Joined: 31 Mar 2006 Posts: 123 Location: Millinocket, Maine
				 Posted: Wed Jun 21, 2006 4:22 pm    Post subject: AZUSA Breaks |
				Buy one of the complete kits available, you'll be better off, money- time.
 Matco, Hegar, Azusa all have different options. Some include tires and all.
 Vic
 Maine
  _________________ MKIIIX040
912UL |
		ulflyer(at)verizon.net Guest
				 Posted: Wed Jun 21, 2006 9:02 pm    Post subject: AZUSA Breaks |
				John,
 Couple options, going to band brakes, they may work better than
 expansion brakes.  Next check out Tracy O'Brien hydraulic brakes.  A
 friend put them on his Hawk and they worked really well.
 http://www.tracyobrien.com/moreinfo.asp?id=47
 He has a nose dragger so he didn't use them in a differential
 fashion, you may want to with a tail dragger.  With band brakes there
 would be minimum change, may require adding a flange to the axle
 bracket to mounting the band to and reuse the existing cables and
 activator.  May have to add a flange for the O'Brien brakes also.  On
 his Hawk, all he had to do was drill two holes into the existing
 flange on each axle bracket.  Bleeding them out properly required
 more attention.  Once properly bled out, they have worked great and
 have plenty of holding power for his plane.
 jerb
 At 11:41 AM 6/21/2006, you wrote:
 because I am less than satisfied with the 15 year old brakes despite
 III, etc, but I think this would be over kill on a Firestar.
 Thanks.
 John Murr
				 Posted: Thu Jun 22, 2006 9:41 am    Post subject: AZUSA Breaks |
				John,
 Another thought - one of the problems I've had with the Azusa
 expansion type brakes is there drums are not perfectly round which
 causes grabbing as the wheel rotates.  Also this is influenced by
 what wheels you have,  - the wheel barrow type wheels where you had
 to center the drum best you could and drill holes through the steel
 wheel to mount the brake drum.  If you have wheels that allow the
 drums to be mounted using the wheels manufactured hole pattern, they
 may work a little better, but the drums in side surface still are not
 perfectly round.  I have seen drums offered where they turn the
 inside surface to true up the drum, but they cost more.  I previously
 made comment about using band brakes which can have two issues, do
 they produce enough braking power for your size aircraft (probably
 would) and how well do they work once they get wet?  The O'Brien
 really work well plus you can easily remove a wheel unlike some of
 the others out there.  Give them more thought.
 jerb
 Thanks.
 John Murr
