cookflys
Posted: Mon Jan 13, 2014 9:58 pm Post subject: Ballast in front for models 2 & 3 582 engines |
Do any of you mod 2 or 3s have any weight added to front?
I saw a model 2 and model 3 with weight added under the front engine mount. It was ice tray with lead melted in it. I have no idea how much it weighs but my model 2 tail has always seemed heavy in flight.
My battery is behind my seat.
C Cook
_________________ Charles Cook
Model II 582
#363 |
Michel
Posted: Tue Jan 14, 2014 1:02 am Post subject: Re: Ballast in front for models 2 & 3 582 engines |
In my humble opinion, when considering the CoG of a Kitfox, the most important thing is that, in case of elevator failure, the aircraft climbs at full throttle and descent at idle throttle.
Next, can you do a 3-points landing without difficulties? After the 582, I installed a Jabiru on my Kitfox 3 and that added weight forward. I couldn't get the tailwheel to touch the ground first when at stall speed. I then moved the battery from the bulkhead (standard place, I think, for the model 3) to, behind the seat. I still had difficulties to land 3-point. I then gap sealed the elevator and now it works.
Any lead ballast in an aircraft seems to me like a poor idea. I am sure the CoG can be placed in a better place by other means.
Michel
_________________ Kitfox 3 - Jabiru 2200 |
mikelaundy(at)yahoo.co.uk Guest
Posted: Tue Jan 14, 2014 4:04 am Post subject: Ballast in front for models 2 & 3 582 engines |
I suggest you have the aircraft accurately weighed so you can check the C of G is within limits. In my MK3 the battery is just aft of the engine bulkhead, the C of G is nicely within limits although I do find I run out of up elevator approaching the stall or when trying to do a 3 point landing.
Also on my mk 3 the angle of incidence on the horizontal stabiliser is adjustable, you may be able to adjust that on your aircraft to make it feel less tail heavy provided the C of G is within limits.
Mike Laundy
Mk3 Rotax 582 Cornwall UK
On Tuesday, 14 January 2014, 9:08, Michel <michel(at)online.no> wrote:
[quote] --> Kitfox-List message posted by: "Michel" <michel(at)online.no (michel(at)online.no)>
Next, can you do a 3-points landing without difficulties? After the 582, I installed a Jabiru on my Kitfox 3 and that added weight forward. I couldn't get the tailwheel to touch the ground first when at stall speed. I then moved the battery from the bulkhead (standard place, I think, for the model 3) to, behind the seat. I still had difficulties to land 3-point. I then gap sealed the elevator and not it works.
Michel
http://forums.matronics.com/viewtopic.php?p=416883#416========================http://www.matronics.com/Navigator?Kitp; -->
poasttown(at)yahoo.com Guest
Posted: Tue Jan 14, 2014 6:08 am Post subject: Ballast in front for models 2 & 3 582 engines |
Michel
When I had a 582 attached to the front of my Mod. IV I added some weight. I put lead shot in a two inch PVC pipe and then glued two end caps to contain the shot. I then attached the pipe to the cabin side of the firewall.
On a side note. From what I hear about melting lead you need to be careful about the fumes produced from the melting process.
Mike
1996 Kitfox IV/Jabiru
On Tuesday, January 14, 2014 4:12 AM, Michael Laundy <mikelaundy(at)yahoo.co.uk> wrote:
Mike Laundy
| Quote: | --> Kitfox-List message posted by: "Michel" <michel(at)online.no (michel(at)online.no)>
Michel
http://forums.matronics.com/viewtopic.php?p=416883#416883
[quote]http://www.matronics.com/Navigatronics.com/" target="_blank" rel="nofollow">http://forums.matronics.co-> [b]
jconnell(at)fmwildblue.co Guest
Posted: Tue Jan 14, 2014 8:07 am Post subject: Ballast in front for models 2 & 3 582 engines |
Hi Charles,
I have a Kitfox-II with a 582. My battery (lawn mower type) is located aft of the firewall on the pax side. Two 6 gallon wing tanks with the header tank behind the seat...
Joe
Time: 09:58:48 PM PST US
Subject: Ballast in front for models 2 & 3 582 engines
From: Charles <cookflys(at)yahoo.com (cookflys(at)yahoo.com)>
C Cook
Float Flyr
Posted: Tue Jan 14, 2014 8:55 pm Post subject: Ballast in front for models 2 & 3 582 engines |
I agree that C of G needs to be accurately measured . My preference is to set up the plane according to the construction manual. The only deviation to that is the set up for floats... Instead of measuring the step location I prefer to calculate the cg of the floats and then locate that cg directly below the cg of the plane sans wheels... That way the plane will balance properly for take off.
Noel
Sent from Yahoo Mail on Android From: Michael Laundy <mikelaundy(at)yahoo.co.uk>;
To: kitfox-list(at)matronics.com <kitfox-list(at)matronics.com>;
Subject: Re: Re: Ballast in front for models 2 & 3 582 engines
Sent: Tue, Jan 14, 2014 12:04:10 PM
Mike Laundy
| Quote: | --> Kitfox-List message posted by: "Michel" <[url=javascript:return]michel(at)online.no[/url]>
Michel
http://forums.matronics.com/viewtopic.php?p=416883#416======================== http://www.matronics.com/Navigator?Kitp; -->
[b]http://www.matronilow" target="_blank" href="http://forums.matronics.com">http://forums.m= --> |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Jim Shumaker
Posted: Wed Jan 15, 2014 8:33 pm Post subject: Ballast in front for models 2 & 3 582 engines |
The feeling of being tail heavy does not mean anything if your CG is not correct. The trim speed on the model 3 is set with the horizontal stabilator position. If the CG is within the envelope then the Stabilator incidence can be set for pitch trim at cruise. When that is set then you may feel the plane become more tail heavy when you add a passenger....that is it will fly hands off at a slower speed with two in the plane than with one....depending on the weight distribution of the passenger. I have found that small passengers with cushions behind them do not change the trim much. Heavy passengers generally make the plane fly a little slower with the CG slightly further aft.
All that being said, it is better to move the battery forward than to add weight.
Jim Shumaker
Model 3 1200 hours
Rotax 912ul (nose heavy)
To: "kitfox-list(at)matronics.com" <kitfox-list(at)matronics.com>
Sent: Tuesday, January 14, 2014 6:08 AM
Subject: Re: Kitfox-List: Re: Ballast in front for models 2 & 3 582 engines
Michel
Mike
Mike Laundy
Michel
| Quote: | [b]http://www.matro====================
_________________ Jim Shumaker |
