Van's SB 14-01-31
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
n146wb(at)cfu.net
PostPosted: Sun Feb 02, 2014 7:59 am    Post subject: Van's SB 14-01-31 Reply with quote
This is a heads up in case you haven’t heard about this yet. It calls for inspection of the horizontal stabilizer front spar before further flight. This is definitely a safety issue so don’t blow it off. I haven’t done the inspection yet and I really hope I don’t have cracks as the repair appears to be a nasty job. To view the bulletin, go to the following: http://www.vansaircraft.com/public/service-rv6.htm. The bulletin goes on to say that this inspection should be done during each annual until the repair is accomplished. It seems they are telling us that sooner or later cracks will show up. This applies to 6’s, 7’s and 8’s both tri-gear and tailwheel. It would be interesting to know how many folks find cracks and at what numbers of hours. It also would be interesting to see if the repair work is as bad as it sounds in the SB.
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
