JabiruEngine-List Digest: 2 Msgs - 02/06/14
4rcsimmons(at)comcast.net
PostPosted: Fri Feb 07, 2014 2:16 am    Post subject: JabiruEngine-List Digest: 2 Msgs - 02/06/14 Reply with quote
Hello,
I not flying yet but in a conversation with another jabiru pilot, they, (2 planes, 2 jabiru's, same concern) actually reduced throw on the carb butterfly. We are talking a small amount.
It was states that they still felt the engine was a full power but the butterfly valve didn't quite make 100% open.
My conversation with them was carb airflow concerns I had while still building. The concerns where stimulates from the past 8 years of listening to this forum. That is how this subject came up.
Anyhow, may be worth a Try only using 95% butterfly movement or at least reducing in small increments on a trial basis.
Safe flying!
- Rich
On Feb 7, 2014, at 2:02 AM, JabiruEngine-List Digest Server <jabiruengine-list(at)matronics.com> wrote:
Today's complete JabiruEngine-List Digest can also be found in either of the
of the JabiruEngine-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 14-02-06&Archive=JabiruEngine
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 14-02-06&Archive=JabiruEngine
JabiruEngine-List Digest Archive
Total Messages Posted Thu 02/06/14: 2
Today's Message Index:
1. 11:19 PM - Rough running Jab 3300 (Gary Eady)
2. 11:36 PM - Re: Rough running Jab 3300 (Paul Mulwitz)
________________________________ Message 1 _____________________________________
Time: 11:19:40 PM PST US
Subject: Rough running Jab 3300
I'm having a few issues with my Jab 3300 solid lifter engine. Intermittentl
y, normally under load in the climb, it develops a miss in either one or ot
her of the front cylinders. The miss/rough running only lasts between about
10 and 20 seconds and recurs every couple of hours or so of flying - but i
s enough to make me look around quickly for an off field landing area.=0AHa
ve checked the resistance and condition of the HT leads and also the coils.
All seem to be ok.=0AThe errant cylinder is easy to track via the EGT prob
es and is always number 1 or 2 which is suddenly about 100 degrees C cooler
than the others.=0AThe engine has 70 hours on it and starts well hot or co
ld - is burning no oil and throws virtually no oil into the breather bottle
.. All engine parameters are great including cylinder head temps. Except for
this darn miss.=0A=0AAnyone else out there having or had a similar problem
??=0A=0A=0ARegards=0A=0AGary=0A=0ACH701,- Jab 3300A serial number 500, 70
hours total time. Grand Rapids EIS.
________________________________ Message 2 _____________________________________
Time: 11:36:41 PM PST US
Subject: Re: Rough running Jab 3300
Hi Gary,
First let me say I am no expert on engines of any sort. So don't depend
on my being right.
I once had some strange miss-firing because the carburetor was loose.
It was more dramatic than your story and only went bad when I reduced to
idle power for descent.
The thing that comes to mind listening to your story is you are at a
high angle of attack. That suggests there is something about the air
flow to the carburetor might be funny. In my plane I took extra
measures to straighten out the air flow just in front of the
carburetor. There are several ways to do this, and I don't really know
if any are necessary.
A 3300 is a large engine for a 701. You must get very high pitch on the
aircraft nose when climbing. This suggests a possible problem with fuel
pressure could be involved. Do you have a boost pump?
Good luck,
Paul
Camas, WA
Zodiac XL, Jab 3300
> Intermittently, normally under load in the climb, it develops a miss
> in either one or other of the front cylinders. The miss/rough running
> only lasts between about 10 and 20 seconds and recurs every couple of
> hours or so of flying - but is enough to make me look around quickly
> Have checked the resistance and condition of the HT leads and also the
> coils. All seem to be ok.
> The errant cylinder is easy to track via the EGT probes and is always
> number 1 or 2 which is suddenly about 100 degrees C cooler than the
> others.
> The engine has 70 hours on it and starts well hot or cold - is burning
> no oil and throws virtually no oil into the breather bottle. All
> this darn miss.
> Anyone else out there having or had a similar problem??
> Regards
> Gary
> CH701, Jab 3300A serial number 500, 70 hours total time. Grand Rapids EIS.
