sarg314(at)comcast.net Guest
Posted: Sat Jun 24, 2006 12:22 pm Post subject: KT-76C lighting |
Perhaps some one with a KT-76C transponder can explain this.
I have an old KT-76C, not installed yet, and am trying to figure out the
display lighting. The operating manual describes adjusting the display
brightness by selecting "TST" mode and pushing the 0 key to decrease
brightness and 7 key to increase it. Sounds great - it controls it's
own brightness.
However, the pinout on the connector specifies that pin 2 should be
hooked up to the 14v panel light dimmer. Why 2 brightness controls?
Does this input on pin 2 actually power the LED display? Why not just
connect this to +12v and use the front panel feature to control
brightness? If I do hook this up to a dimmer, how much power does it
draw? I can't find any reference to power consumption in the specs.
Tom Sargent, RV-6A
FLYaDIVE(at)aol.com Guest
Posted: Sat Jun 24, 2006 1:53 pm Post subject: KT-76C lighting |
In a message dated 6/24/06 4:25:37 PM Eastern Daylight Time,
sarg314(at)comcast.net writes:
| Quote: | However, the pinout on the connector specifies that pin 2 should be
Tom Sargent, RV-6A
Tom:
The purpose of hooking up the KT-76C to the panel light dimmer is ONLY to
have the entire panel light system TURNED ON & OFF from one common point. Once
it is On then you can adjust the light intensity on the Xponder as you wish.
The only part you or the instructions did not mention is WHERE on the dimmer do
you tap off the power? You do want ON & OFF control of the panel lighting
BUT as you guessed, if the power tap off is on the adjusted output then if the
panel lights are DIM the Xponder lights may be nonexistent. All you really
need is common ON - OFF control of the lights for the Xponder.
Barry
"Chop'd Liver"
