kees de bussy
Joined: 16 Jul 2009 Posts: 18 Location: the netherlands
Posted: Mon Mar 03, 2014 3:11 am Post subject: EASA noise certificate |
Hi all,
In order to renew a special airworthness certificate (permit to fly) I need a copy of EASA noise certificate of a Europa XS trigear with Rotax 914 fitted with a groud adjustable Warp drive propeller with C or N blades. Anybody out there who can help me out ?
Kees de Bussy
PH-GOO (previous F-PSMU)
ptag.dev(at)talktalk.net Guest
Posted: Mon Mar 03, 2014 3:56 am Post subject: EASA noise certificate |
In his day Dave Bosomworth fixed me up on an emergency basis once when I was
at Templhof Berlin ! but it was for a Woodcomp SL 3000 CS prop. but don't
split hairs though !!Regards
\Bob Harrison G-PTAG
davidjoyce(at)doctors.org Guest
Posted: Mon Mar 03, 2014 4:59 am Post subject: EASA noise certificate |
Kees, Noise certificates are available from the Europa
club. You should find details on the website
(www.theeuropaclub.org) or simply contact the chairman.
Regards, David Joyce, G-XSDJ
On Mon, 3 Mar 2014 11:56:13 -0000
prop. but don't
kees de bussy
Posted: Tue Mar 04, 2014 1:33 am Post subject: Re: EASA noise certificate |
Hi Bob and David,
Thanks for your input. Unfortunately it is not that simple. I do have the Europa Club noise certificate but that is not accepted by the Dutch authorities. The only thing which is valid is a EASA noise certificate ( issued by a EASA certified ANMI, Aircraft Noise Measurement Institute) of an aircraft which is equipped with exact the same engine, propeller and exhaust.
In all other cases we have to go through a time consuming procedure where aircraft performance and noise is measured by a certified organisation. We are lucky, in so far, that there is such an institute in the Netherlands which can do all the measurements at reasonable costs. But of course if I can find a comparable Europa with EASA noise certificate it will save time and money.
Anyway, thanks again for trying to help me out but probably we have to do it via the long way.
Kees de Bussy
