Bipedream
Posted: Thu Mar 06, 2014 9:21 pm Post subject: Two into one or three into one solder splice |
I've been searching for a good guide on the proper way to create a solder splice for two wires into a single wire. I'm also interested how to splice three wires into a single wire.
I assume that's been covered a number of time but my searching technique on the forum may need a little help.
I saw a good article on the www.aeroelectric.com/ on doing a simple two wire solder splice but I didn't see one on this particular issue.
My radio (Flightline FL-760) has two power connections in the DSUB connector that I need to splice into the single power wire. I also need three grounds pins on the DSUB spliced into the ground wire.
I'm using machined DSUB pins and rotary crimp tool on the connector side.
jmjones2000(at)mindspring Guest
Posted: Thu Mar 06, 2014 9:49 pm Post subject: Two into one or three into one solder splice |
A Solder sleeve would work great for this application. Google "Solder sleeve". There are a few YouTube videos out there that show how to use them in this exact application.
Justin
On Mar 6, 2014, at 20:21, "Bipedream" <smittss1c(at)hotmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=419901#419901
Bipedream
Posted: Fri Mar 07, 2014 1:52 am Post subject: Re: Two into one or three into one solder splice |
Would a crimped splice also be okay? I already bought some and don't want to also buy the heat gun needed to use the solder splice you mentioned if I can avoid it.
rickofudall
Posted: Fri Mar 07, 2014 6:34 am Post subject: Two into one or three into one solder splice |
You don't want to buy tools? I can't even imagine such a thing. How will you chronicle your life if you can't look back on the tool you bought 30 years ago and never used again? Heresy! Pure heresy!
Rick Girard
On Fri, Mar 7, 2014 at 3:52 AM, Bipedream <smittss1c(at)hotmail.com (smittss1c(at)hotmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "Bipedream" <smittss1c(at)hotmail.com (smittss1c(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=419905#419905
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
