Electric gas pump.
franicaza(at)yahoo.com.mx
PostPosted: Wed Mar 12, 2014 5:21 am    Post subject: Electric gas pump. Reply with quote
Hello list,
Mine is a Kitfox S6 with Rotax 912 100HP. I want to install an electric bump, just in case. Any ideas where it should be placed?
Thanks in advance,
Francisco Icaza, Mexico City.
http://paralelo19n.blogspot.mx
Enviado desde mi iPad
aerobatics(at)aol.com
PostPosted: Wed Mar 12, 2014 5:58 am    Post subject: Electric gas pump. Reply with quote
Sure after the Gasolator if you have one, inside the fire wall.... and as low as practical but above the Gasolator. A facet pump that delivers between about four and six psi. Even though your aircraft is a highwing with tanks basically gravity fed having electric pump is a very good idea. Put on a separate switch so you can do your run up with out using it to prove that your mechanical pump is working fine.
Good luck!
Sent via DroidX2 on Verizon Wireless™
-----Original message-----
To: kitox list <kitfox-list(at)matronics.com>
Sent: Wed, Mar 12, 2014 13:22:02 GMT+00:00
Subject: Kitfox-List: Electric gas pump.
Hello list,
Thanks in advance,
lcfitt(at)sbcglobal.net
PostPosted: Wed Mar 12, 2014 7:16 am    Post subject: Electric gas pump. Reply with quote
I mounted mine as close to the header tank outlet as possible.  This proved to be just aft of the bungee bulkhead as the seat pretty much takes all the room near the header tank.
Lowell Fitt
Model IV-1200
Rotax 912 UL
On 3/12/2014 6:56 AM, aerobatics(at)aol.com (aerobatics(at)aol.com) wrote:
[quote] body {word-wrap: break-word; background-color:#ffffff;} Sure after the Gasolator if you have one, inside the fire wall.... and as low as practical but above the Gasolator. A facet pump that delivers between about four and six psi. Even though your aircraft is a highwing with tanks  basically gravity fed having electric pump is a very good idea. Put on a separate switch so you can do your run up with out using it to prove that your mechanical pump is working fine.
Good luck!
From: franicaza(at)yahoo.com.mx (franicaza(at)yahoo.com.mx)
To:
kitox list <kitfox-list(at)matronics.com> (kitfox-list(at)matronics.com)
Sent:
Subject:
Electric gas pump.
--> Kitfox-List message posted by: franicaza(at)yahoo.com.mx (franicaza(at)yahoo.com.mx)
Hello list,
Thanks in advance,
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronics.com/Navigator?Kitfox-List
���~���,�g���M4�G�q���z����.�'�8*+_���&j)E���K��j��',.+- 歺��5�h����,x zf�ȸ���b�+bz�.r�.+-Rҹ��*m���!���y�܄:0�Zw�����ǂ��E��h��y�ݚ�!��!������i��0�f����r�(��Z�(��ʊ��ĸ��m���� ���'���o�j��j�+*+_����M� $�NEC&z �j�(�ק��l��ڊV����j�^Y�Ţ��������ߢ���f����r�(�m��ߢ���f����r�(����*'����ب�g�J+^8�L���+ʋ���ޮ����i��1�m�������)j�|���� &j��',r��r���&�*'��i��0�f����r�(��(���n�b����ߢ{���n�r�fl=== [b]
MDKitfox(at)aol.com
PostPosted: Wed Mar 12, 2014 7:31 am    Post subject: Electric gas pump. Reply with quote
Hi Francisco,
I have Series V with a 912 100HP. I mounted my facet boost pump under the passenger seat and close to the outlet of the header tank. It's easily accessible if there are any future maintenance issues. It's been trouble free since I started flying it 5 years ago. I do have a 3 way switch on the instrument panel. Down is pump on. Up is momentary on and must be held in the up position to operate the pump, and the middle is off.
Whatever you do, be sure to run a fuel flow test to ensure proper flow rates. Do this at all possible flight attitudes. If I remember correctly, AC90-89 is a good source for how to do fuel testing. Also, EAA has a video on their website explaining how to run the tests.
Hope this helps.
Fly Safe.
Rick Weiss
Series V (Skystar s/n 1) Speedster:-)
Rotax 912S, Dynon Sky View
Spruce Creek Fly In, FL
MDKitfox(at)aol.com (MDKitfox(at)aol.com)
On Mar 12, 2014, at 9:56 AM, aerobatics(at)aol.com (aerobatics(at)aol.com) wrote:
[quote]Sure after the Gasolator if you have one, inside the fire wall.... and as low as practical but above the Gasolator. A facet pump that delivers between about four and six psi. Even though your aircraft is a highwing with tanks basically gravity fed having electric pump is a very good idea. Put on a separate switch so you can do your run up with out using it to prove that your mechanical pump is working fine.
Good luck!
To:
kitox list <kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)>
Sent:
Subject:
Electric gas pump.
Hello list,
Thanks in advance,
Enviado desde mi --> http://www.matroniclass="Apple-converted-space"> http://www.matronics.com/co=================
lloydeggstaff(at)gmail.co
PostPosted: Thu Mar 13, 2014 4:45 pm    Post subject: Electric gas pump. Reply with quote
I have read somewhere that an electric fuel pump should be plumbed in parallel with the mechanical pump. It sounds like you all have plumbed them in series. Is that right? If that's true it makes for an easier installation.
On Thu, Mar 13, 2014 at 10:16 AM, Sally and Craig Nelson <c.s.nelson(at)msn.com (c.s.nelson(at)msn.com)> wrote:
[quote] I have a S6 firewall back with S7 firewall forward and 912ULS. After a few years of flying I decided to add a Facet electric pump. I mounted it under the center console just after the fuel valve. I do the run up with it off and switch it on for takeoff and landing only. It has worked well. I agree on the comments on thefuel flow test.
Craig
Eden Prairie, MN
Sent from Windows Mail
uuccio(at)gmail.com
PostPosted: Thu Mar 13, 2014 8:25 pm    Post subject: Electric gas pump. Reply with quote
Hi Lloyd
In series is correct. The Rotax mechanical pump does not have a known failure modes where it fails blocking the passage of fuel. Make sure the same holds true for the electrical pump or else fit a one way bypass valve in parallel to it.
Sacha
