Posted: Fri Mar 21, 2014 6:07 am Post subject: Damping grease definitive answer |
here is the definitive answer for the damping grease from a very helpful chap called Tom Madden
Hi Will,
I just heard back from Nye's Technical Support Department. They stated that the 767A is only good down to 0 degrees c. They are recommending what is being used on Boeing's landing gear, Rheolube 374A. Attached is the Technical Data Sheet and MSDS for your review. The price is as follows.
50 gram tube: $34.95
100 gram tube: $49.95
500 gram jar: $89.95
There is no minimum order. Lead time is 5 to 10 business days for the tubes. I currently have the 500 gram jars in stock and can ship when ordered. We accept Visa/MasterCard.
If you have any other questions before ordering, please feel free to contact me. I look forward to doing business.
Tom Madden
TAI Lubricants
PO Box 1579
Hockessin, DE 19707
USA
(302) 326-0200
(302) 326-0400 fax
nyoil(at)aol.com (nyoil(at)aol.com)
www.lubekits.com
William Daniell
LONGPORT
+57 310 295 0744
brian.davies(at)clara.co. Guest
Posted: Fri Mar 21, 2014 7:19 am Post subject: Damping grease definitive answer |
Will,
I think there has been a misunderstanding here. The Rheolube 374A is, I think, a high spec. multipurpose lubricating grease, not a damping grease. Nye do a damping grease that will work at lower temps if you are worried about that aspect. The 868 range or 774 range will give you this characteristic.
Brian Davies
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of William Daniell
Sent: 21 March 2014 14:06
Subject: Damping grease definitive answer
Hi Will,
Tom Madden
TAI Lubricants
PO Box 1579
Hockessin, DE 19707
USA
(302) 326-0200
(302) 326-0400 fax
www.lubekits.com
William Daniell
LONGPORT
+57 310 295 0744
| Quote: | | http://www.matronics.com/Navigator?Europa-List | 01234567
Checked by AVG - www.avg.com
Version: 2014.0.4336 / 03/21/14
