Instrument Panel Studs, and US supplier of small hardware it
tonyrenshaw268(at)gmail.c
PostPosted: Sun Mar 23, 2014 9:12 pm    Post subject: Instrument Panel Studs, and US supplier of small hardware it Reply with quote
Gidday,
I’m stuck and was hoping someone could resurrect my momentum. I need to know how long to make my instrument panel studs to accommodate a washer, possibly conical, and probably only on the cockpit side, as the other side should use either metal or phenolic washers. This means I am having permanent studs out the back of the panel, going through the firewall, and being secured on the engine compartment side of the firewall. I’m going to use AN3 bolts, with their heads Reduxed onto the brackets I have incorporated into the internal flange over the top and along the bottom horizontal edge of the back of the panel. Sourcing of appropriate and recommended suppliers for these washers appreciated, as I don’t seem to easily be able to source them at home.
Lastly, I was going to research the US supplier for all sorts of small bits and pieces of hardware, but I can’t remember it for the life of me, nor can my brains trust.
Thanks.
Tony Renshaw
Sydney Aussie.
