		Kellym
				 Posted: Sun Apr 06, 2014 6:24 pm    Post subject: radios |
				In the real world with a good, properly installed antenna, you and ATC
 will not notice the difference between 6 watts and 10 watts.
 Most of the old KX 170 and 155 series radios as well as the Narco Mk 12
 series were in the 7-8 watt range.
 To really see a performance difference you need to step up to the 16-20
 watt output, and unless you fly in the flight levels is pretty hard to
 justify the cost.
 On 4/6/2014 6:28 PM, Gary Bennett wrote:
  The unit in question is the Garmin GPS 400W (at) $ 3,995. It does NOT include
  NAV/COM. So add another $4,495 to that for a NAV/COM unit and now you are in
  GTN 650 territory. Yes, Dynon offers a COM unit (as does AFS and others) but
  they tend to be 6 WATT transmitters compared to the 10 WATT (16 optional)
  Garmin offering. Adding a NAV radio means sticking with the big-name brands
  and price-tag.
KCHD |
		stein(at)steinair.com Guest
				 Posted: Sun Apr 06, 2014 7:30 pm    Post subject: radios |
				That is definatley true.  At the frequncies and levels we are talking about, the differences aren't exactly linear...meaning that a 40% increase in wattage doesn't necessarily and automatically equate to a 40% increase in perceived or real performance. That said, the  higher power radio will often "step on" the lower powered one in some instances.  There are a lot more variables that affect radio quality than pure wattage.  I've seen some panel mounted 5W handhelds with and exceptionally good installation outperform a poorly installed 10W radio. Again, just a lot of variables that don't make things an absolute!
 Cheers,
 Stein
 On Sunday, April 6, 2014, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
 [quote] --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com>
  In the real world with a good, properly installed antenna, you and ATC will not notice the difference between 6 watts and 10 watts.
  Most of the old KX 170 and 155 series radios as well as the Narco Mk 12 series were in the 7-8 watt range.
  To really see a performance difference you need to step up to the 16-20 watt output, and unless you fly in the flight levels is pretty hard to justify the cost.
   	  | Quote: | 	 		   --> RV10-List message posted by: "Gary Bennett" <gary(at)bendun.net>
  and price-tag.
  http://forums.matronics.com
  le, List Admin.
