		whodja
  Joined: 27 Jan 2014 Posts: 50 Location: Apex NC (near Raleigh)
				 Posted: Mon Apr 07, 2014 4:06 am    Post subject: Planning to order the QB fuselage and wings at AirVenture |
				Can anyone tell me about what is included in the QB finishing kit? When I finish my tail kit and order the wing and fuselage QB kits, how much lead time and in what order will I need to plan on my avionics and engine?
 Thank you,
 Tal Holloway
 Apex, NC
		Bob Turner
				 Posted: Mon Apr 07, 2014 9:03 am    Post subject: Re: Planning to order the QB fuselage and wings at AirVentur |
				Hi Tal,
 As Carl said, order avionics last. They change so fast that anything you buy today will be obsolete before you fly. Also - contrary to everything else - they are becoming less expensive or more capable (your choice).
 As he noted, you may save a few dollars shipping if you order the finish kit (same kit, slow or quick build) with the QB wings and fuselage. But you will need storage space for it. In the past (2008) the QB fuselage and wings could have backlogs as long as 4 months. Call Vans and ask for the current status (I think it's on their web site but may not be the latest info). Finally, the engine. What is your plan? If you were hoping to find a good used one they are rare, you just have to watch constantly. If an overhaul, ask your overhauler about lead times and time to find a useable core. If factory new, you have a choice. These things have been inflating faster than the stock market, so you may consider buying it and the prop (Vans offers a $1K discount if you buy both at the same time) during this year's OSH/AirVenture. They usually have a special, like free shipping and free long term preservation oil. Otherwise, engine lead times are a few months.
  _________________ Bob Turner
RV-10 QB |
		jack(at)bedfordlandings.c Guest
				 Posted: Mon Apr 07, 2014 11:57 am    Post subject: Planning to order the QB fuselage and wings at AirVenture |
				Tal,
 I would suggest you keep an eye out for a good deal on an engine (unless you
 are planning on buying a new engine).  I was able to find a very good deal
 on an O-540-A1D5 from a Piper Aztec on eBay a couple of years ago.  The
 engine has 60 hours SMOH and I got it, the logs, and the entire firewall
 forward assembly from the Aztec (including alterhator, starter and vacuum
 pump) for $13,000.
 I had planned to buy a core of an IO-540 for about $12K and then put $15K in
 new parts in it, overhauling it myself.  Even though I wasn't sure what I
 was getting with this eBay purchase, I felt it was worth it for the money
 just to have as a core.  I was surprised and pleased to see that it was
 better than advertized, with new Millenium Cylinders, new Slick mags and
 good shops used for the overhaul.  So good deals are out there - you just
 need to look for them
 Now I just need to get back to work on the project.
 Jack Phillips
 #40610
 Smith Mountain Lake, Virginia
 Wings and Tail done.  Need to buy the Fuselage Kit.
		michaelrorth
				 Posted: Mon Apr 07, 2014 12:39 pm    Post subject: Planning to order the QB fuselage and wings at AirVenture |
				FOR SALE
  3 ENGINES & 1 PROP
  ENGINE #1-RIGHT
  CONTINENTAL 10-470L
  S/N 91968-5-L
  TTSO 1489.8
  COMPLETE ENGINE & PROPELLER PITCH CONTROL.
  COMPLETE LOGS.
  REMOVED FROM BEECHCRAFT BARON THAT LANDED GEAR-UP. INCIDENT HAS NOT BEEN  ENTERED INTO ENGINE LOG.
  OIL DRAINED AND SHOWED NO SIGN OF CONTAMINATION.
  OIL-PAN DROPPED AND VISUAL INSPECTION SHOWED NO SIGN OF DAMAGE.
  MY FEELING IS THAT THIS ENGINE DID NOT SUFFER ANY DAMAGE AS THE RESULT OF  THE ACCIDENT.
  COULD BE USED IN A/C, AIRBOAT, OR HOVERCRAFT.
  PRICE $5,000 USD; YOU PAY SHIPPING.
  ENGINE #2-LEFT
  CONTINENTAL 10-470L
  S/N 91945-5-L
  TTSO 1457.8
  COMPLETE LOGS
  ENGINE #3
  LYCOMING IO-540 G1D5
  S/N L-9927-48
  TTSO 5.43
  COMPLETE LOGS
  PROP #1
  HARTZELL HC-92WK-1DW
  TTSO 2.12
  S/N S/N AC-206
  PRICE-ENGINE & PROP $18,000 USD. YOU PAY SHIPPING.
  THIS IS HOW THE ENGINE WAS DESCRIBED TO ME:
  “…. purchased the engine and prop from Westair International Company,  Monument, CO 80132 Jim Cullen is the owner. (719) 481-2286 He sold a number of  these engines and was recommended to me by Murphy. They thought this was a  perfect engine for their plane. I called a fellow who bought one from him to  check up on his transaction. He was very pleased with Jim and the engine and  prop. (His name is John Knutson, Chicago, (312) 642 0335 home (312) 383 1300 x  104 work) I believe he was putting it into his homebuilt. I haven't talked to  him in ten years so I don't know if the numbers are still good. The engine  arrived as promised and is complete with magnetos, harness, fuel pump, Bendix  injection system, alternator and starter. It is preserved, and includes platinum  spark plugs (not installed--the plug holes have the things in them that absorb  moisture--I can't remember what they are called!) There are three tech manuals  also. It is still in the shipping crate which has always been in my heated shop.  I looked in it today and it looks good. The IO-540 G1D5 engine serial number is  L-9927-48. It is rated as 290 HP, max rpm 2575. The Hartzell Propeller Model  HC-92WK-1DW S/N AC-206 The engine has a total of 799.22 hours since new. It has  5.43 hours since overhaul. The propeller has a total of 731.12 with 2.12 since  overhaul. There are two complete log books for the engine and one for the  propeller.
  My concern before buying was that they came out of an IAR 823 airplane  which was a plane used by the Romanian Air Force! (I Googled it and it looks  like a Mooney to me.) I checked with several engine building people (including  the company that overhauled my Cessna engine) who told me the overhaul facility  in Romania is noted for quality services. (BOAC had them do all their engine  maintenance.) A fellow on the Murphy group, George Coy (who now sells M14P  radials and was building a Moose--put this IO-540 in his plane. I asked him why  not use one of his radials and he said he was going to put it on floats in  Vermont and could not have any oil dripping into their pristine lakes. I guess  coffee cans wired under the jugs does not meet environmental standards for  catching 100% of the oil!
  The log books are all in Romanian but I had someone go over them with me  (they spoke Romanian) and they are very detailed and complete. I was going to  sit down with this person and rewrite each entry but haven't yet. I got a new  English engine log from Jim Cullen--I'm not sure it is really necessary to  translate the old ones. I feel comfortable with the accuracy of the logs and the  work that has been done. A mechanic where I get my Cessna serviced was  interested in using the engine for his tow plane--checked out the engine and  logs, said it looked good but then found his mounts or something were different  and it wouldn't fit. He offered my $20,000 for it! (I should have paid for his  new mounts!) Hope this is the info you needed--I think it is the right motor for  the Murphy. I've watched a friend mess with a M14 radial in his Moose but his  struggles with the cowl, oil leaks, air start, parts, mounts and extra fuel  burn, etc. etc. convinced me a good old 290 HP Lycoming was what I felt most  comfortable with.”
  Michael Orth
  Beaver Valley, British Columbia, Canada
  mosurf(at)xplornet.com
  (250)  243-0013
