Horz stab and elv hinge SB's
Charles Heathco
PostPosted: Mon Apr 07, 2014 7:30 am    Post subject: Horz stab and elv hinge SB's Reply with quote
2 part question. I am not builder but think I can make these inspections and hopefully enter that no problems found. If problems found I should be able to make repairs, OR get help from my A&P who signs off my annual to help if needed. Am I right about this? 2000 flying RV6A under 400 hr TT
ceengland7(at)gmail.com
PostPosted: Mon Apr 07, 2014 7:57 am    Post subject: Horz stab and elv hinge SB's Reply with quote
On any homebuilt experimental in the USA, *anyone* can do *anything* that's maintenance or repair related, *except* the annual condition inspection, which must be signed off by either the repairman's certificate holder or someone holding at least an A&P ticket. As the owner, you can sign off any other repairs or inspections.
Hope that helps,
Charlie
mrobert569(at)hotmail.com
PostPosted: Mon Apr 07, 2014 8:02 am    Post subject: Horz stab and elv hinge SB's Reply with quote
On an amateur-built aircraft anybody may do the maintenance but only the builder, certificated as a repairman, or an A&P may conduct the yearly condition inspection (annual).  Make sure you check the aircraft's operating limitations (which are supposed to be in the aircraft at all times) to see any restrictions and limitations.
Mike Robertson
Das Fed
To: rv-list(at)matronics.com
Subject: Horz stab and elv hinge SB's
Date: Mon, 7 Apr 2014 10:29:11 -0500
get=_blank>http://www.matronics.com/Navigator?RV-List
tp://forums.matronics.com
=_blank>http://www.matronics.com/contribution
decaclops(at)gmail.com
PostPosted: Mon Apr 07, 2014 7:44 pm    Post subject: Horz stab and elv hinge SB's Reply with quote
As the guys have said, you can do the work, if you can do the work that
is. The disassembly and repair involves drilling out a bunch of rivets,
some of which will be hard to get to and will require the skillful use
of an angle drill. Do yourself a favor and get some
experienced/qualified help, if repairs are required. Seems unlikely that
a 400hr airplane will have cracks, but it does need to be looked at closely.
Ed Holyoke
