Slime Fighter oil separator
woxofswa
PostPosted: Tue Apr 08, 2014 2:41 pm    Post subject: Slime Fighter oil separator Reply with quote
Any PIREPS on the Slime Fighter RV-10 product and/or vs the ASA product or any other product? Just getting painted and would like to keep it clean.
Thanks in advance. Getting close to engine start!
Myron Nelson
Mesa, AZ
Flew May 10 2014
flying-nut(at)cfl.rr.com
PostPosted: Tue Apr 08, 2014 4:42 pm    Post subject: Slime Fighter oil separator Reply with quote
I'm opinionated so you may take this with a grain of salt .... whatever
that means Wink
Air/oil separators are great for covering up a problem .... if you're
getting that much blowby then it's time to look at fixing the problem.
With a new engine you shouldn't need one to keep the belly clean. If
you're really anal about it, shorten up the vent tube and fix a can
under it to catch the drips. If you do go the air/oil separator .....
drain the 'gunk' into a can too.
Linn
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse on gear. FWF complete.
http://forums.matronics.com/viewtopic.php?p=421803#421803
Checked by AVG - www.avg.com
bill.peyton
PostPosted: Thu Apr 10, 2014 5:46 am    Post subject: Re: Slime Fighter oil separator Reply with quote
Check out VAF. there is a complete discussion in the RV-10 group and in the general discussion area
Bill
WA0SYV
Aviation Partners, LLC
