bob88
Posted: Sun Apr 20, 2014 1:11 pm Post subject: Door Seal |
Can the McMaster Carr door seal, applied to the lip on the cabin cover, be removed/replaced if it is floxed on as a couple of people have reportedly done?
Posted: Sun Apr 20, 2014 2:08 pm Post subject: Door Seal |
On 4/20/2014 5:11 PM, bob88 wrote:
Haven't tried using fox to attach the door seal .... and don't know why
you would .... my MMC door seal has a spring metal liner that grips the
lip of the cabin cover. If the lip is too thin in places then you can
squeeze the metal to help it grip.
Linn ..... painting the interior
Posted: Sun Apr 20, 2014 4:33 pm Post subject: Door Seal |
On 4/20/2014 6:05 PM, Linn Walters wrote:
why you would .... my MMC door seal has a spring metal liner that
grips the lip of the cabin cover. If the lip is too thin in places
then you can squeeze the metal to help it grip.
Ditto.
Checked by AVG - www.avg.com
EdKranz
Joined: 29 Dec 2010 Posts: 132 Location: Hastings, MN
Posted: Mon Apr 21, 2014 6:18 am Post subject: Door Seal |
Yes.
I used the seal as a form to build the edge back up to the proper thickness. I just filled the seal with flox and installed it on the lip. It came off nicely in a single pull.
Now, I only let is sit on there for two days or so while the epoxy cured, then I peeled it off. I don't know how things would change if it were on there longer.
On Sun, Apr 20, 2014 at 7:31 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
[quote] --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
| Quote: | --> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
| Quote: | --> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
| Haven't tried using fox to attach the door seal .... and don't know why you would .... my MMC door seal has a spring metal liner that grips the lip of the cabin cover. If the lip is too thin in places then you can squeeze the metal to help it grip.
Ditto.
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
_________________ Ed Kranz
RV10
Finishing
www.edandcolleen.com |
