tonyrenshaw268(at)gmail.c Guest
Posted: Mon Jun 09, 2014 2:24 am Post subject: Stick Grips |
Gidday,
I have a pair of Tosken Manufacturing Stick Grips, but the way they are raked forward is giving me grief. I’ve already cut them down to suit, which works by having a 1” insert with a smaller diameter hole that the grip mounts through. So, I am after a stick grip that has a male stud sticking out the bottom that goes into a receptacle that fits inside our sticks, NOT over them. Any suggestions??
Tony Renshaw
peterz(at)zutrasoft.com Guest
Posted: Mon Jun 09, 2014 2:55 am Post subject: Stick Grips |
Not having installed my nifty Tosten (www.tostenmanufacturing.com) grips yet, I was wondering if the raked condition could be rectified by milling up some custom off-axis grip-mount-plugs instead of replacing them totally?
Cheers,
Pete
On Mon, Jun 9, 2014 at 6:23 AM, Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)> wrote:
[quote]--> Europa-List message posted by: Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)>
Gidday,
Tony Renshaw
st" target="_blank">http://www.matronics.com/Navigator?Europa-List
MS -
e -
     -Matt Dralle, List Admin.
budyerly(at)msn.com Guest
Posted: Mon Jun 09, 2014 4:09 am Post subject: Stick Grips |
Tony,
When going with other than the MAC style stick grips, you are in custom
territory.
I have had custom bending and welding done with a stud, and also with a
military style multipin connector in the top of a stick. I find that custom
stick grips usually come with proper spacers for 1 and 7/8 inch tubes. I
would bet that the stick manufacturer has a solution to the fitting, but not
the cockpit clearances.
The issue, as you have found, is the cockpit clearance is going to require
you to replace your sticks with custom bends to allow the grip head, at your
comfortable flying position, to give clearance all around the cockpit.
Nothing worse than testing an aircraft whose control limit stops are the
panel and persons anatomy. Also check the passenger side as well.
Bud Yerly
Sent: Monday, June 09, 2014 6:23 AM
Subject: Stick Grips
Gidday,
Tony Renshaw
Posted: Mon Jun 09, 2014 4:33 am Post subject: Stick Grips |
Hi Bud, Am I right that I can tinker with winding out the rod end at the bottom of the control column, to get the whole range of the stick further aft. It appears though the longer you make that arc, it alters the way the pitch pushrod travels within the aileron tube, and you could create a bind. Unfortunately I have a nice little 1 1/2" fence of 2 plies of BID that creates a surface to protect my controls, and to allow a boot to attach to, which is basically in the way of future close inspection. I think I might just rely on sound and feel throughout the control movement range. Irritating, and unforeseen.
Tony Renshaw
Sent from my iPad
| Quote: | On 9 Jun 2014, at 10:08 pm, "Bud Yerly" <budyerly(at)msn.com> wrote:
Tony,
When going with other than the MAC style stick grips, you are in custom territory.
I have had custom bending and welding done with a stud, and also with a military style multipin connector in the top of a stick. I find that custom stick grips usually come with proper spacers for 1 and 7/8 inch tubes. I would bet that the stick manufacturer has a solution to the fitting, but not the cockpit clearances.
The issue, as you have found, is the cockpit clearance is going to require you to replace your sticks with custom bends to allow the grip head, at your comfortable flying position, to give clearance all around the cockpit. Nothing worse than testing an aircraft whose control limit stops are the panel and persons anatomy. Also check the passenger side as well.
Bud Yerly
> Gidday,
> Regards
> Tony Renshaw
kingsnjan(at)westnet.com. Guest
Posted: Mon Jun 09, 2014 5:09 am Post subject: Stick Grips |
Tony,
Take it from a friendly banana bender from the Sunshine State ......... push bike handlebar grips are cheap and functional ..... Heh heh
Sent from my iPad
| Quote: | On 9 Jun 2014, at 10:33 pm, Tony Renshaw <tonyrenshaw268(at)gmail.com> wrote:
Tony Renshaw
Sent from my iPad
> Tony,
> Regards,
> Bud Yerly
> From: "Tony Renshaw" <tonyrenshaw268(at)gmail.com>
>> Gidday,
>> Regards
>> Tony Renshaw
Fred Klein
Posted: Mon Jun 09, 2014 6:24 am Post subject: Stick Grips |
Tony…my mantra for all things aviation:
“…manage the degree of novelty…”
Fred
PS: I’m a lousy manager.
On Jun 9, 2014, at 5:08 AM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
[quote]Tony,When going with other than the MAC style stick grips, you are in custom territory.[b]
Posted: Mon Jun 09, 2014 12:09 pm Post subject: Stick Grips |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Tony,
You are better off rebending the stick. Your gut to panel distance must be judged. The pitch rod travel is fixed more or less by geometry of the system, only slight changes are made there. Make a new stick custom to your grip. As for limits, your knees, gut and panel will determine what the stick shape and size need to be. What is important is 13+, -5 on the stab and your gut and panel (including knuckles) do not limit that at any aileron travel limit. Latterally, make sure the pain necessary to do full deflection is not noticeable in roll. Take it on a bit of faith, and note that tall grips create more of a pain and rework than they give back in enjoyment. It can add another 40 hours to the build.
Unless your ego cannot live without it, it is a cut/bend/fit exercise. The KISS principle was applied to my bird because of doing 12 gotta have custom grips discussions.
The last time I pulled a trigger on a stick, bad things happened to other people on the ground, I don't have one. I still fly with my index finger extended.
Bud
Posted: Mon Jun 09, 2014 1:53 pm Post subject: Stick Grips |
Except I have cut down the sticks!
T
Sent from my iPad
| Quote: | On 9 Jun 2014, at 11:08 pm, Kingsley Hurst <kingsnjan(at)westnet.com.au> wrote:
Tony,
Sent from my iPad
> Regards
> Tony Renshaw
> Sent from my iPad
>> Tony,
>> Regards,
>> Bud Yerly
>>> Gidday,
>>> Regards
>>> Tony Renshaw
europa471
Posted: Mon Jun 09, 2014 4:13 pm Post subject: Stick Grips |
Question for those who have test flown their Europa.
How far can you shorten the control stick and still comfortably land the
aircraft with the stabilizer stuck at full travel in either direction ,
without being Superman?
Lance Sandford
On 10/06/14 07:52, Tony Renshaw wrote:
T
Sent from my iPad
> Tony,
> Do not archive
> Sent from my iPad
ptag.dev(at)talktalk.net Guest
Posted: Tue Jun 10, 2014 12:10 am Post subject: Stick Grips |
Answer:- NO SHORTER WHATEVER. TO LAND FULLY NOSE UP TRIM IT WOULD BE Extremely difficult on your own ! but power assisted by the passenger probably ! But the extreme loads are a question over the mechanical strengths of the linkages ! When I had to go to fully trimmed up to get the damn relay deck to reverse it was easier to let it go fully nose up trim and pray the deck would let itself reverse when it got to the end of travel. Been there done that when Menzimer was insisting my problem was wiring when in actual fact they eventually discovered that the end of the travel by the relay masked the actual problem in the relay . Since I fitted the MARK II relay deck never a problem !!!!!
Bob Harrison G-PTAG
Posted: Tue Jun 10, 2014 12:11 am Post subject: Stick Grips |
Tony .......get new sticks of the already bent type. See my answer to Lance Stanford.
|Bob Harrison. G-PTAG
Posted: Tue Jun 10, 2014 12:39 am Post subject: Stick Grips |
Hi Bob,
Like me, mine are already BENT!
So, I think if I can get the bits I chopped off the ends stuck in the middle, I might be right. How come the curved sticks weren't more curved, receding further aft and less forward?
I think I know the answer.
Tony Renshaw
Sent from my iPad
[quote] On 10 Jun 2014, at 6:10 pm, "Bob Harrison" <ptag.dev(at)talktalk.net> wrote:
europa471
Posted: Tue Jun 10, 2014 1:56 am Post subject: Stick Grips |
Bob
Thanks Bob. That is about what I suspected.
Lance Sandford
Bob Harrison G-PTAG
Remi Guerner
Posted: Tue Jun 10, 2014 2:05 am Post subject: Re: Stick Grips |
<<<<How>>>>>
Lance,
I assume you are talking about possible pitch trim runaway. I did some testing a few years ago with my aircraft and this is what I found:
at my typical 130 kts cruise speed if the servo goes to the full pitch up position, the necessary push force is so high that it is impossible to maintain level flight. After reducing power and speed, the push force is still very high. It is possible to maintain level flight but it will be very tiring after a few minutes.
Still at cruising speed, if the servo goes to the full down position, the pull force is high but it is possible to maintain level flight even at cruise speed. After reducing power and speed, the pull force is still high but it is possible to maintain level flight quite easily.
Testing was done with the standard stick. Obviously a shortened stick will make things worse.
I believe it is critical to have the pitch trim circuit breaker well marked so that you can turn it off before it goes all the way up or down. In case of a runaway to the up position, a trick is to bank the aircraft and turn, therefore releasing the push force. Then, while you are doing 360s, you can relax and take time to decide what you are going to do next.
Remi Guerner
F-PGKL, XS monowheel, 1100 hours
Posted: Tue Jun 10, 2014 2:28 am Post subject: Stick Grips |
Hi! Tony.
Don't be fooled by the bend. It is not all about forward and aft bending you will need to use the existing bend partly rotated to achieve best position.
Bob Harrison G-PTAG
Posted: Tue Jun 10, 2014 3:01 am Post subject: Stick Grips |
Yep.
TR
Sent from my iPad
[quote] On 10 Jun 2014, at 8:27 pm, "Bob Harrison" <ptag.dev(at)talktalk.net> wrote:
Hi! Tony.
Bob Harrison G-PTAG
europa471
Posted: Tue Jun 10, 2014 3:20 am Post subject: Stick Grips |
Remi
Thanks for the additional info. I assumed it would be a handful in
cruise. It is the approach and landing loads I was interested in. Some
sort of a kill switch would be a good idea, I´m using fuses not circuit
breakers.
Lance Sandford
On 10/06/14 20:05, Remi Guerner wrote:
Lance,
Remi Guerner
http://forums.matronics.com/viewtopic.php?p=424612#424612
Posted: Tue Jun 10, 2014 4:20 am Post subject: Stick Grips |
whassat....Bob I dont remember that issue can you enlighten on the trim issue please
Will
William Daniell
LONGPORT
+57 310 295 0744
On Tue, Jun 10, 2014 at 4:56 AM, Lance Sandford <sandford(at)melbpc.org.au (sandford(at)melbpc.org.au)> wrote:
[quote] --> Europa-List message posted by: Lance Sandford <sandford(at)melbpc.org.au (sandford(at)melbpc.org.au)>
Bob
Lance Sandford
[quote] --> Europa-List message posted by: "Bob Harrison" <ptag.dev(at)talktalk.net (ptag.dev(at)talktalk.net)>
Answer:- NO SHORTER WHATEVER. Â TO LAND FULLY NOSE UP TRIM IT WOULD BE Extremely difficult on your own ! but power assisted by the passenger probably ! But the extreme loads are a question over the mechanical strengths of the linkages ! Â When I had to go to fully trimmed up to get the damn relay deck to reverse it was easier to let it go fully nose up trim and pray the deck would let itself reverse when it got to the end of travel. Been there done that when Menzimer was insisting my problem was wiring when in actual fact they eventually discovered that the end of the travel by the relay masked the actual problem in the relay . Since I fitted the MARK II relay deck never a problem !!!!!
Bob Harrison G-PTAG
Posted: Tue Jun 10, 2014 5:20 am Post subject: Stick Grips |
Hi! William
................Just don’t shorten the control stick .....use the bent one and fix it by rotating it to best position.
Bob Harrison.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of William Daniell
Sent: 10 June 2014 13:20
Subject: Re: Stick Grips
Will
William Daniell
LONGPORT
+57 310 295 0744
Bob
Lance Sandford
Bob Harrison G-PTAG
Posted: Tue Jun 10, 2014 5:50 am Post subject: Stick Grips |
Thanks...but you had a runaway trim?  if is was a particular model I am wondering whether I shd change my trim motor (Mac) prior to putting the top on  (I cant imgaine this is much fun with the top on!)
William Daniell
LONGPORT
+57 310 295 0744
On Tue, Jun 10, 2014 at 8:19 AM, Bob Harrison <ptag.dev(at)talktalk.net (ptag.dev(at)talktalk.net)> wrote:
Hi! William
................Just don’t shorten the control stick ......use the bent one and fix it by rotating it to best position.
Bob Harrison.
Â
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of William Daniell
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Â
Will
William Daniell
LONGPORT
[url=tel:%2B57%20310%20295%200744]+57 310 295 0744[/url]
Â
Bob
Lance Sandford
Bob Harrison G-PTAG
