Posted: Wed Apr 23, 2014 2:02 pm Post subject: Voltage drop thru the essential bus diode as shown in Z-9. |
At 04:08 PM 4/23/2014, you wrote:
| Quote: | I am getting about 3/4 of a volt drop through the essential buss
diode when the battery is at a full 12 volts. When I throw the
essential bus feed switch the Voltmeter creeps back up to 12 volts.
Is this fairly normal? Thanks. John
Yes. Diodes do have a small drop associated with
them . . . which is insignificant when the alternator
is running (bus at 14+ volts) and even less significant
when the alternator is not running because the alt-feed
switch is closed and the main bus is shut down.
