ptag.dev(at)talktalk.net Guest
Posted: Mon May 05, 2014 12:04 pm Post subject: Rotax 9xx oil From the OTHER BOB .......BOB HARRISON G-PTAG |
IMHO the  recommended Shell M0-Cycle oil doesn’t accommodate the extreme cam lobe pressures on the prop- strike cams in front of the gearbox evidenced by a unsatisfactory magnetic plug.
I am testing the use of a tin of Halfords extreme Pressure STP oil per oil change, but heat it and mix it well before you put it in the engine. I have about 150 hours now with no cam erosion and clean magnetic plug since commencing this procedure.
Bob Harrison G-PTAG
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of James Kelly
Sent: 05 May 2014 16:39
Subject: Re: Rotax 9xx oil
Hi Bob,
It's my understanding that any quality branded 4stroke motorcycle oil is recommended !
rgds
Jim
On Mon, May 5, 2014 at 4:21 PM, Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
Gents:
This is the oil developed by Shell & Rotax for use in Rotax 4-cycle engines. It's semi-synthetic so it can be used with both MoGas & AvGas.
If you can get it, why use anything else?
Best regards,
Bob Borger
| Quote: | | http://www.matronics.com/Navigator?Europa-List | 01234567
