O-320 Non Meshing Starter Motor Gear
genie(at)swissmail.org
PostPosted: Sat May 03, 2014 8:55 am    Post subject: O-320 Non Meshing Starter Motor Gear Reply with quote
When starting my Lycoming O-320 I hear the gnashing of teeth and the
propeller hardly rotates. It is as if the starter motor's gear wheel
hardly engages. I do manage to rotate the propeller and start, but just
barely and after many repeated attempts. I have had the battery checked
and it is OK. Please let me know what the problem could be and possible
solutions.
Thanks.
George Nielsen
RV-6 PH-XGN
The Hague, the Netherlands
dalamphere(at)comcast.net
PostPosted: Sun May 04, 2014 1:40 am    Post subject: O-320 Non Meshing Starter Motor Gear Reply with quote
George,
Your problem sounds like a starter problem. The solenoid is not
pushing the starter gear into the flywheel teeth.
David
just barely and after many repeated attempts. I have had the battery
checked and it is OK. Please let me know what the problem could be
and possible solutions.
Thanks.
George Nielsen
RV-6 PH-XGN
