Vacuum Pump - How does this happen?
FLYaDIVE(at)aol.com
PostPosted: Fri Jun 23, 2006 6:50 pm    Post subject: Vacuum Pump - How does this happen? Reply with quote
HI Team:
In the past month I have worked on three vacuum systems. With each vacuum
pump there is a set of instructions that say "clean the tubing so no debris will
enter a gage". My question is this:
If a vacuum pump draws air FROM the canister air filter, through the
instruments and vacuum gage AND pumps the exhaust air out the pump through the rear
tube ... HOW does derbies manage to go the REVERSE direction from the pump back
to the instruments?
Barry
"Chop'd Liver"
GrummanDude
PostPosted: Mon Jun 26, 2006 5:24 am    Post subject: Vacuum Pump - How does this happen? Reply with quote
In a message dated 6/23/06 7:52:09 PM, FLYaDIVE(at)aol.com writes:
It's a "cover our ass" statement.  If your filter is clean (the one going to the instruments) tha's all you need to worry about.
Gary
AuCountry Aviation
Home of Team Grumman
