n5lp(at)warpdriveonline.c Guest
Posted: Fri Jun 23, 2006 7:12 pm Post subject: Trio EZ Pilot-Redux |
Howdy,
I was very discouraged with my brand new Trio EZ-Pilot last night
after having found out it is not plug and play with my Navaid
autopilot and then discovering baffling turn coordinator display
issues and accompanying strange aircraft behavior. Tonight I am
greatly encouraged and happy about my decision to get the EZ-Pilot.
Tonight I treated the machine in a way it would be normally treated
after an install. First I took a hint from Gary Sobek and moved just
one of my analog steering wires to a different position on the GPS
connector and to a different position on the old Navaid connector.
That let the GPS talk to the EZ-Pilot. Then I verified, on the
ground, that the connection was working properly, then started up and
flew.
Things were completely different than yesterday. First I tried all
the EZ-Pilot functions, and there are some real nice ones. I think
the one I will use the most is where you are tracking a course line,
then ATC tells you to turn 15 degrees right, rather than disengage
the autopilot and have to hand fly, you can just give it the course
to fly, then intercept the old course later, if needed. Everything
worked beautifully and smoothly.
Then I tried to duplicate what happened yesterday by turning off the
GPS, entering calibration screens, turning off the autopilot and
everything I could think of, in every order I could think off, but I
could not confuse the autopilot. About the worst thing I could get
to happen would be to do a steep turn then return to wings level
flight and the turn coordinator would very slightly and briefly
overshoot, showing an opposite direction turn.
The only thing I can think of is what the Trio engineer suggested
this morning. Since I never had the GPS working correctly yesterday,
the gyro (gyros?) may never have gotten properly oriented and may
have used an out of date bias value. As stated in their literature,
they do not use gravity to help orient the gyro. Today I tried what I
was worried about yesterday. I would fly a course then turn off the
GPS. No problem, it just gave a no GPS warning and kept trucking. I
would then maneuver (everything short of aerobatics) and return to
straight and level with proper indications the whole time. I also
tried wings level yaws, and yes the indicator reacts to that. In a
stable slip it indicates level/straight, which seems logical.
And yes, if you were already using digital GPS information for your
existing Navaid, it would be a fifteen minute installation, although
Trio doesn't make that claim. If you were using analog steering
information, you have to run one new wire, or move an existing one over.
By the way, those of you in the tailwheel, versus tri-gear debate,
which I don't participate in, here is some fodder. The tailwheel
airplane is at a big disadvantage when you drop those little tiny
screws and nuts from the D connectors onto the uncarpeted floor
while upside down working in a restricted area under the panel. They
scurry straight downhill and lodge under the spar (RV-6) where they
are lost forever.
I really appreciate the great and cheerful support Trio gave me
today. You guys have a terrific product.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
http://n5lp.net
pbesing(at)yahoo.com Guest
Posted: Sat Jun 24, 2006 11:41 pm Post subject: Trio EZ Pilot-Redux |
Haven't flown mine yet...still finishing up the
install. I can tell you this, TruTrak has some
serious competition for the wing leveler/heading
market. I sent my TruTrak Digitrak back.
So far from the support, manual, and features, this
thing is a slam dunk. TruTrak may have great higher
end autopilots, but this thing blows the digitrak
away. Oh and Navaid? It was a sweet ride while it
lasted!
How many autopilot companies monitor and respond to
RV-List questions...on the weekend, no less?
Paul Besing
RV-4 N73DD
Arizona
Haven't even flown the Trio and lovin' it.
--- Larry Pardue <n5lp(at)warpdriveonline.com> wrote:
Howdy,
EZ-Pilot last night
my Navaid
coordinator display
Tonight I am
get the EZ-Pilot.
normally treated
position on the GPS
Navaid connector.
verified, on the
then started up and
flew.
First I tried all
ones. I think
than disengage
give it the course
needed. Everything
turning off the
autopilot and
think off, but I
thing I could get
wings level
and briefly
engineer suggested
oriented and may
their literature,
then turn off the
kept trucking. I
and return to
time. I also
to that. In a
logical.
analog steering
tri-gear debate,
The tailwheel
those little tiny
uncarpeted floor
the panel. They
(RV-6) where they
are lost forever.
Trio gave me
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
http://n5lp.net
browse
Subscriptions page,
FAQ,
Admin.
Posted: Mon Jun 26, 2006 11:38 am Post subject: Trio EZ Pilot-Redux |
On Jun 25, 2006, at 1:35 AM, Paul Besing wrote:
I don't know how many autopilot companies monitor the list but I know
it is done by companies that sell things likely to go in RVs. The
last three electronic items I have added to my RV have had issues I
have posted to the list about. These items were an EFIS a high end
portable GPS and an autopilot. The GPS brand is a major
international corporation.
In each case I was contacted by the company, at my work place, very
quickly. I don't even know how they got the phone number. Also in
each case the company was very courteous and just wanted to get to
the bottom of the problem. In one instance they wanted to know when
it would be convenient for "a team of engineer" to call me back.
This contrasts greatly to what is happening at my workplace now,
where I have been trying to return a damaged piece of equipment to
Office Depot for over a month. The equipment was quickly replaced
but we are still on the hook for the damaged thing until we get
credit for the return. I am caught in a never ending circle of
contacting a Philippine call center which assures me that I will be
called back and when I am called back, by an American, I am assured
the item will be picked up in two days. There is no accountability
and no capability of calling the same person back. Now there is a
way to drive a bunch of customers away for life.
As for the RV equipment, I think pretty much anyone is not too
bothered by some minor problems, as long as the company is responsive.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
http://n5lp.net
