				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| Roland
		| Back to top |  |
		| davidjoyce(at)doctors.org Guest
				|  Posted: Sat May 10, 2014 3:37 am    Post subject: Europa Crash in Lübeck/Germany |   |
				| I strongly suspect that this another case where a SmartASS
or the equivalent might have saved them both. David Joyce,
 G-XSDJ
 On Sat, 10 May 2014 02:10:05 -0700
 "JonSmith" <jonsmitheuropa(at)tiscali.co.uk> wrote:
  	  | Quote: |  	  | <jonsmitheuropa(at)tiscali.co.uk>
 It has obviously impacted the ground very hard for
 reasons I am certainly not going to speculate about.  I
 feel the survivability in any aircraft under the
 circumstances would be problematical - indeed I feel it
 stands testament to the Europa design that one person at
 least was able to survive.  Personally I feel more
 comfortable in my Europa than any other aircraft.
 G-TERN
 Classic Mono
 http://forums.matronics.com/viewtopic.php?p=423105#423105
 Un/Subscription,
 Forums!
 Admin.
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
				|  Posted: Sun May 11, 2014 2:21 am    Post subject: Europa Crash in Lübeck/Germany |   |
				| Jim, Google Smart Avionics. Not sure whether the Mark 3
SmartASS is up on the site yet but if not it will be
 shortly. The Mark 2 went out of production late last year.
 The Mk 3 is in being , has been flight tested, will be on
 sale shortly and slightly cheaper than the mark 2, I am
 told.
 On Sun, 11 May 2014 00:40:59 -0700
		| Back to top |  |
				|  Posted: Sun May 11, 2014 9:07 am    Post subject: Europa Crash in Lübeck/Germany |   |
				| Graeme, I can tell you that you can fly with one flap up &
one down! I am ashamed to say (but too old to be too
 ashamed - having seen that pretty much everyone makes some
 sort of cock up if they carry on flying long enough!),
 that I managed to rig my mono with the flap pin on one
 side in front of the flap socket. It looked normal on walk
 around, but proved very entertaining when I put gear up
 and only one flap came up, the other staying half down. It
 wasn't too much of a problem although certainly would have
 been had I been doing say 40kts. And just to say that your
 near name sake who started this thread is a very sane and
 very experienced builder responsible for numerous Europa
 mods, who has enormous experience of the development of
 the Europa. His remarks are worth taking seriously
 Regards, David Joyce, G-XSDJ
 On Sun, 11 May 2014 08:48:11 -0700
 "graeme bird" <graeme(at)gdbmk.co.uk> wrote:
  	  | Quote: |  	  | <graeme(at)gdbmk.co.uk>
 Is it a stall? my first thought was i would probably be
 putting the wheel away to get some climb about there;
 what if a flap pin was a bit short or the flap one side
 moved out board and only one was brought up?
 Certainly those first few flights are risky even with
 the best inspections.
 As for saying one wrong sweep when sanding the leading
 edge will radically affect the stall characteristics, is
 that true or help our cause? Perhaps a little alarmist -
 no sane builder is going to put a flat on it.
 Graeme Bird
 G-UMPY
 Mono Classic/XS 912S/Woodcomp 3000/3W
 Newby: 105 hours 26 months on the Mono
 g(at)gdbmk.co.uk
 http://forums.matronics.com/viewtopic.php?p=423177#423177
 Un/Subscription,
 Forums!
 Admin.
		| Back to top |  |
		| graeme bird
				|  Posted: Sun May 11, 2014 9:57 am    Post subject: Re: Europa crash in Lübeck/Germany |   |
				| Interesting to hear that you can fly with a flap down; but for me a lot is going on just after take off, watching the gauges, the speed the VSI, changing prop pitch, unlocking to get the wheel up and pushing the leaver with the right hand etc - maybe the spring/tension is a bit off if its first flight, I am not sure how I would cope if there were to be a sudden roll at that point.
 Yep I also value Grahams wisdom and contributions; I am just thinking of the message, unintentionally, its sending to current builders. The fact is hundreds have been made by imperfect amateurs and the stall characteristics are one of the first things explored during the test flights.
 Graeme Bird
 kit4 (Wagstaff) TBD
 Kit 1 G-UMPY -  Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
