		| Author | Message |
		| davidjoyce(at)doctors.org Guest
				|  Posted: Sun May 11, 2014 2:43 am    Post subject: Europa Crash in  Lübeck/Germany |   |
				| Graham, Sorry to be butting in on your debate with Tim,
and I see where you are coming from now, but can I just
 add that the SmartASS is g compensated so it gives exactly
 the same 'margin over stall' information as an AOA device
 (and at a fraction of the price). It might appear that I
 am pushing this as if I had some commercial tie up, which
 is not the case. I am evangelical about it because we have
 now had (subject to confirmation in this latest case) 6
 Europas lost to stall/spin accidents, an appalling
 statistic for a plane that flies so beautifully and is
 slippery enough not to lose speed rapidly. There have of
 course been countless crashes of other types also, but in
 our relatively small and tight knit Europa community it is
 truly sobering and we should all be asking ourselves are
 we confident of not becoming number 7.
 Regards, David Joyce, G-XSDJ
 On Sun, 11 May 2014 11:22:00 +0100 (BST)
 GRAHAM SINGLETON <grahamsingleton(at)btinternet.com> wrote:
  	  | Quote: |  	  | Tim maybe we are mixing things a bit. ASI will measure
 instantly changes in airspeed.
 When AoA changes aircraft speed will not change
 instantly but will take several seconds.
 The force causing change of airspeed is increase or
 decrease in drag, usually quite a small force.
 During take off acceleration is caused by engine thrust
 and ASI will record speed of course, as soon
 as the aircraft is flying AoA should quickly settle at
 best climb.
 Stall occurs at the same AoA whatever airspeed or total
 weight is. (I'm thinking aloud here)
 In fact best climb, cruise or glide speeds are also at
 fixed AoAs. They are not at fixed airspeeds but
 change as all up weight changes.
 AoA is much the best primary flight control instrument.
 That's why fast jets use it.
 A pity AoA meters aren't mass produced like ASIs are!
 best regards
 Graham
 Sent: Sunday, 11 May 2014, 8:34
 Subject: Re: Re:
 Re: Re: Europa Crash in
 Lübeck/Germany
 Hi Graham.
 We may be talking apples against pears here BUT if what
 you say is true then on takeoff I would be at 100'
 thinking about retracting the undercarriage before the
 ASI has moved from zero.
 I agree it takes time to accelerate or decelerate a
 600kg mass but the pressure measurement showing movement
 relative to the local air mass will be indicated within a
 small fraction of a second even using our normal
 mechanical manometers that are calibrated in airspeed and
 could be even quicker using electronic pressure sensors
 close to the pitot head.
 True an AOA or alpha system would be helpful but I just
 want to be warned if through lack of attention or being
 distracted I allow my speed to decay , these lack of
 attention or distraction events usually build up slowly
 without it being noticed and I would guess rarely happens
 over one or two seconds.
 best regards
 On 10 May 2014 22:28, GRAHAM SINGLETON
 >don't think so , the ASI won't move (or shouldn't!) until
 >the aircraft has accelerated, or worse slowed down and
 >that takes many seconds.
 >When it says "stall speed!" you.ve already stalled. Not a
 >lot of use.
 >Graham
 >________________________________
 > From: houlihan <houlihan(at)blueyonder.co.uk>
 >To: europa-list(at)matronics.com
 >Sent: Saturday, 10 May 2014, 14:31
 >Subject: Re: Re:
 >Hi Graham.
 >I think you may have put the decimal point in the wrong
 >place. I appreciate what you are suggesting but 20
 >seconds ?
 >I bet the real figure is much less than a second.
 >Mind you how would you measure the lag , my ASI seems to
 >move at the speed of light at times.
 >Tim
 >On 10 May 2014 13:19, GRAHAM SINGLETON
 >Or an AoA meter as primary attitude/speed instrument. The
 >ASI is always 20 seconds too late.
 >>Very sad, I met Manfred while he was building. A very
 >>nice man and a nice Europa.
 >>Graham
 >> From: David Joyce <davidjoyce(at)doctors.org.uk>
 >>Sent: Saturday, 10 May 2014, 12:36
 >>Subject: Re: Europa Crash in Lübeck/Germany
 >>I strongly suspect that this another case where a
 >>SmartASS or the equivalent might have saved them both.
 >>David Joyce, G-XSDJ
 >>arget="_blank">http://www.matronics.com/Navigator?Europa-List
 >>tp://forums.matronics.com
 >>_blank">http://www.matronics.com/contribution
 >http://www.matronics.com/con================
 _blank">http://www.========================
		| Back to top |  |
				|  Posted: Sun May 11, 2014 7:10 am    Post subject: Europa Crash in  Lübeck/Germany |   |
				| Graham, You should probably be contacting Mark Burton for
a definitive answer to that, but my understanding is that
 the mark 2 SmartASS and the upcoming mk 3 (as opposed to
 the mk 1) have solid state accelerometers built in and
 they modify the speed slow & speed very slow messages in
 realtion to the increased g effect on stall speed so that
 if you are set for 60 as your approach speed if you pull a
 60 degree bank whilst maintaining 60kt she will get
 agitated
 and tell you 'speed slow' or probably 'very slow'. You are
 of
 course increasing the AOA to achieve that bank angle and
 the signal would go from probably yellow to red and the
 associated audible warnings on the new Bendix King AOA
 system would show comparable change.
 I accept that inaccurate profiling might
 change
 the stall speed and behaviour and favour a wing drop, but
 nevertheless I feel strongly that the underlying critical
 factor in the sort of disasters we are talking about is
 allowing the speed to decay dramatically whilst heavily
 distracted in a highly stressed situation. A slightly
 inaccurate Classic wing might stall at say 42kts whilst my
 beautiful XS wing stalls at 38 but neither of us should be
 anywhere near these speeds unless moments from touch down!
 In serious emergencies such as EFATOs even the most
 experienced & qualified pilots can be distracted enough to
 totally ignore speed control, so we all need a system that
 points out in unignorable fashion that our speed is
 getting dangerously slow, when we are looking out of the
 window desperately trying to identify  a place we might
 land without killing ourselves. Student pilots are
 significantly
 more likely to die from stall/spin accidents with an
 instructor
 on board than flying solo. My (& I suspect most)
 stall warner does not fit that bill. It is in the head
 rest and advancing deafness and super new head sets mean
 it is only just audible, and on top of that I am
 used to ignoring it for much of the take off and landing
 runs. Regards, David
 On Sun, 11 May 2014 15:14:08 +0100 (BST)
  	  | Quote: |  	  | David always respect your remarks so no apology needed. I need
 to scratch my bald patch to understand the G compensation
 aspect.
 One of the things that disturbs me somewhat is that
 several of these accidents were with Classics
 Don's excellent airfoil section is very critical to
 inaccuracy around the leading edge and I noticed that
 sanding the LE with templates generated from computer
 printouts made a big difference to the way the wing
 stalled. A single stroke
 in the wrong place with a flat abrasive sander can
 destroy the LE profile.
 regartds
 Graham
 To: europa-list(at)matronics.com Sent: Sunday, 11 May 2014,
 11:42
 Subject: Re: Re: Re:
 Re:  Re: Re:
 > Tim
 >instantly changes in airspeed. When AoA changes aircraft
 >speed will not change instantly but will take several
 >seconds.
 >and ASI will record speed of course, as soon as the
 >aircraft is flying AoA should quickly settle at best
 >climb.
 > best regards
 > Graham
 >8:34
 > Subject: Re: Re:
 >Lübeck/Germany
 > Hi Graham.
 >thinking about retracting the undercarriage before the ASI
 > I agree it takes time to accelerate or decelerate a 600kg
 > best regards
 > Tim
 > Tim
 >>lot of use.
 >> Graham
 >> To: europa-list(at)matronics.com Sent: Saturday, 10 May
 >>2014, 14:31
 >> Subject: Re: Re:
 >> Hi Graham.
 >>place. I appreciate what you are suggesting but 20 seconds
 >> Tim
 >>> Graham
 >>>2014, 12:36
 >>>David Joyce, G-XSDJ
		| Back to top |  |
		| graeme bird
				|  Posted: Sun May 11, 2014 7:48 am    Post subject: Re: Europa Crash in  L�beck/Germany |   |
				| Is it a stall? my first thought was i would probably be putting the wheel away to get some climb about there; what if a flap pin was a bit short or the flap one side moved out board and only one was brought up?
Certainly those first few flights are risky even with the best inspections.
 As for saying one wrong sweep when sanding the leading edge will radically affect the stall characteristics, is that true or help our cause? Perhaps a little alarmist - no sane builder is going to put a flat on it.
 Graeme Bird
 kit4 (Wagstaff) TBD
 Kit 1 G-UMPY -  Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
		| Back to top |  |
