riddon(at)sent.com Guest
Posted: Mon May 12, 2014 1:12 am Post subject: Fuel pump replacement (UK) |
I have just got a new mechanical fuel pump as a routine replacement. ( Although my Pierburg is still fine). Do I need an inspection after fitting and a sign off or can I just bung it on and go flying again?
Richard Iddon.
G-RIXS
pete(at)lawless.info Guest
Posted: Mon May 12, 2014 1:31 am Post subject: Fuel pump replacement (UK) |
Richard
Don't know about the sign off but you should certainly re do the fuel
flow checks.
Pete
On 12/05/14 10:11, Richard Iddon wrote:
Richard Iddon.
G-RIXS
brian.davies(at)clara.co. Guest
Posted: Mon May 12, 2014 2:32 am Post subject: Fuel pump replacement (UK) |
A number of owners have experienced problems caused by high fuel pressure
overcoming the carb float valves after fitting the new pump. I don't know
if you have a fuel pressure gauge fitted but it would be worth checking that
fuel pressure, as well as flow, were still within limits.
It does require an inspector sign off.
Brian Davies
