klehman(at)albedo.net Guest
Posted: Sun Jun 25, 2006 6:50 pm Post subject: Glass Panel Layout and homemade rate gyro |
Interesting info on the rate of turn Bob. I never noticed whether mine
has one or three doghouses. The unit was labelled oddly though by a
factor or 2 as I recall. I never knew why until now. However on 12 volts
it seems to be adequate for my purposes.
There is a company selling a portable attitude indicator that just uses
LED's. A search seems to indicate that there are rate gyros available
that would not be difficult to utilize as a T&B. The confusing display
was indeed the primary reason that I didn't like a TC even before I knew
of the tilted gyro issue.
I also always enjoy your postings.
Ken
OldBob Siegfried wrote:
Good Afternoon Ken,
You will want to be a bit careful when using the
twenty-eight volt unit at a lower voltage. The
sensitivity is drastically reduced. One needle width
will result in a much higher rate of turn than the
standard three degrees per second.
snip
