mjpienaar(at)shaw.ca Guest
Posted: Thu May 15, 2014 8:03 pm Post subject: Gas Struts TR-4 |
Hi All,
Does any body have the specs or the name of the manufacturer for the gas struts that came with the TR-4 to hold the doors open, I wiped my struts with acetone and that took off all the markings
I installed my brackets to conform with the origal struts but they are too weak and I cannot find replacement struts have the same overall length.
Sometime ago there was a mention of a method to recharge the struts and if somebody could point me in that direction I would appreciate it.
Mike
galinhdz(at)gmail.com Guest
Posted: Thu May 15, 2014 8:18 pm Post subject: Gas Struts TR-4 |
The ones I have are GRUDEN gas spring but not sure if they are 6 or 8mm ones.
http://www.guden.com/Control/Standard-Gas-Springs
On Fri, May 16, 2014 at 12:03 AM, Mike Pienaar <mjpienaar(at)shaw.ca (mjpienaar(at)shaw.ca)> wrote:
[quote] Hi All,
Mike
et="_blank">http://www.matronics.com/Navigator?KIS-List
tp://forums.matronics.com
ftyoder(at)yoderbuilt.com Guest
Posted: Thu May 15, 2014 8:32 pm Post subject: Gas Struts TR-4 |
I did that for my TR-1 struts. I got a steel pipe, 1 1/2" ID I think, long enough to hold the strut, capped both ends, you have to seal the threads, drill and tap one cap for a Schrader valve. insert the struts and fill the tube with Nitrogen. I was able to fit four of my struts in my tube. The original rating was 25 lbs. and with the refill they came out at 40 lbs and work much better and last for years.
Tim N52TY
From: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] On Behalf Of Mike Pienaar
Sent: Thursday, May 15, 2014 9:04 PM
To: KISBUILDERS
Subject: Gas Struts TR-4
Hi All,
Mike
://www.matronics..com/Navigator?KIS-List
ics.com
.matronics.com/contribution
This email is free from viruses and malware because avast! Antivirus protection is active. [quote][b]
Posted: Thu May 15, 2014 8:47 pm Post subject: Gas Struts TR-4 |
Tim,
Thanks for you reply, what pressure do you push the nitrogen up to?
Mike
Posted: Thu May 15, 2014 8:49 pm Post subject: Gas Struts TR-4 |
Hi Galin,
I thought taht they were Guden but when I checked the Guden site I could not match them. I will bring them home and re-measure and phone Guden,
Thanks for the help
Mike
Posted: Fri May 16, 2014 3:53 am Post subject: Gas Struts TR-4 |
My bottle doesn't have a gauge and when it is full I think it is less than 2000#.
Sent: Thursday, May 15, 2014 9:47 PM
To: kis-list(at)matronics.com
Subject: Re: Gas Struts TR-4
Tim,
Mike
pfdwind(at)gmail.com Guest
Posted: Fri May 16, 2014 7:02 pm Post subject: Gas Struts TR-4 |
May be I should do that for mine.
On Thursday, May 15, 2014, Tim Yoder <ftyoder(at)yoderbuilt.com (ftyoder(at)yoderbuilt.com)> wrote:
[quote] I did that for my TR-1 struts. I got a steel pipe, 1 1/2" ID I think, long enough to hold the strut, capped both ends, you have to seal the threads, drill and tap one cap for a Schrader valve. insert the struts and fill the tube with Nitrogen. I was able to fit four of my struts in my tube. The original rating was 25 lbs. and with the refill they came out at 40 lbs and work much better and last for years.
Tim N52TY
From: [url=javascript:_e(%7B%7D,'cvml','owner-kis-list-server(at)matronics.com');]owner-kis-list-server(at)matronics.com[/url] [mailto:[url=javascript:_e(%7B%7D,'cvml','owner-kis-list-server(at)matronics.com');]owner-kis-list-server(at)matronics.com[/url]] On Behalf Of Mike Pienaar
To: KISBUILDERS
Hi All,
Mike
Posted: Wed May 21, 2014 5:49 am Post subject: Gas Struts TR-4 |
Thanks Tim, I'n not sure if I want to play with pressures in that range!!!!!! I will look for an alternative and keep that as a measure of last resort.
Thanks for the help
Mike
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Wed May 21, 2014 6:13 am Post subject: Gas Struts TR-4 |
I don't feel like I have much room to give anyone advice on anything since I have yet to finish my project but my take on the door struts is purely one based on observation and a bit of common sense. The doors on both the 2 and 4 place aircraft are rather large and from a pure strength standpoint rather flimsy out of necessity to reduce weight. Having a single strut on only one side of the door, especially one with increased pressure would be putting a constant twisting strain on the door structure each time it is closed. Additionally, when open a gust of wind would put the same or even worse twisting strain on the door. This is why my plan has always been to include two gas struts on each door. They are not expensive and the added weight is minor.
Waiting for life to get out of the way,
Bob Reed
Sent: Wednesday, May 21, 2014 8:49 AM
Thanks for the help
Mike
kentpyle(at)iland.net Guest
Posted: Wed May 21, 2014 1:52 pm Post subject: Gas Struts TR-4 |
I too used two gas struts for each door and for the same reasoning. Kent
Sent: Wednesday, May 21, 2014 9:13 AM
Bob Reed
Thanks for the help
Mike
sstearns2(at)yahoo.com Guest
Posted: Wed May 21, 2014 9:19 pm Post subject: Gas Struts TR-4 |
Be sure to bodywork the doors with the gas struts attached. They flex the door a little. Putting a pair of lower force struts on each door is my plan for the cruiser.
Scott
Subject: Re: KIS-List: Gas Struts TR-4
Bob Reed
Thanks for the help
Mike
fredorosa(at)gmail.com Guest
Posted: Thu May 22, 2014 3:05 am Post subject: Gas Struts TR-4 |
I initially installed the struts only at the forward location of the doors but didn't like the visual intrusion. Now they are only at the rear position. There was some twisting and misalignment when closing the doors so I ordered longer strut anchors for the top location. This neutralized the thrust force alignment so the doors can close properly.
On May 21, 2014, at 5:51 PM, "Kent Pyle" <kentpyle(at)iland.net (kentpyle(at)iland.net)> wrote:
[quote] I too used two gas struts for each door and for the same reasoning. Kent
Bob Reed
From: Mike Pienaar <mjpienaar(at)shaw.ca (mjpienaar(at)shaw.ca)>
Thanks for the help
Mike
Posted: Thu May 22, 2014 11:31 am Post subject: Gas Struts TR-4 |
Mine are Guden GGS22-030-K: http://www.guden.com/Item/GGS22-030-K
and I have 4 of them.
On Thursday, May 22, 2014, Alfred Rosa <fredorosa(at)gmail.com (fredorosa(at)gmail.com)> wrote:
[quote]I initially installed the struts only at the forward location of the doors but didn't like the visual intrusion. Now they are only at the rear position. There was some twisting and misalignment when closing the doors so I ordered longer strut anchors for the top location. This neutralized the thrust force alignment so the doors can close properly.
Bob Reed
Thanks for the help
Mike
