Looking for help...
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
curts63
PostPosted: Thu May 29, 2014 3:19 pm    Post subject: Looking for help... Reply with quote
I purchased a used Lightning, N126NM and had a Garmin 430W installed. The problem is, when I try the RFI test for gps integrity, it more or less fails. In a Lightning, where is the best location and which antenna should be used? I have the GPS receiver located on the top of the fuselage just behind the canopy.
Curt
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
crouchley
PostPosted: Thu May 29, 2014 3:23 pm    Post subject: Looking for help... Reply with quote
Oh no! I just realized I owe you a call! So sorry...I'll call tomorrow
Curt
http://forums.matronics.com/viewtopic.php?p=423996#423996
dwwilt
PostPosted: Thu May 29, 2014 3:46 pm    Post subject: Looking for help... Reply with quote
I am not sure why that location would not work. You do need a ground plane for your GPS antenna. Mine is mounted on my glare shield but it is mounted on a rectanguar piece of aluminum. A ground plane is important for most antennas. Look at the 430W install manual to see if this antenna needs a ground plane.
Blue Skies,
Dennis W. Wilt
N616DW (Arion Lightning S/N 132)
Curt
Dennis
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
