Through-Hole Wire Metal
PostPosted: Wed May 28, 2014 5:06 pm    Post subject: Through-Hole Wire Metal Reply with quote
Some resistors and capacitors have tinned copper leads and some have steel leads. Does it matter? It seems to me that copper is better because it does not rust. What do you think?
Joe
Joe Gores
PostPosted: Thu May 29, 2014 4:42 pm    Post subject: Through-Hole Wire Metal Reply with quote
All components crafted for use in
electronic assemblies have a finish
on leads that is conducive to soldering.
The actual material is seldom an issue
as long as they solder well.
