bob88
Posted: Fri May 30, 2014 7:08 am Post subject: Seatbelt hardware |
I am finishing the doors and would like to mount the overhead seatbelt hardware in the cabin top hard points before priming the cabin cover. However, not yet sure about the color and source of belts. Is there a standard bolt that connects the shoulder harness to the hard point? Any general advice about seatbelts?
Posted: Fri May 30, 2014 7:27 am Post subject: Seatbelt hardware |
It gets a countersunk 5/16" screw. You drill the hold and countersink the cabin top. If you want to mark the hard points, just drill a small hole. Otherwise, you can just wait if you don't cover over the hardpoints and forget where they are. There is no actual hardware that gets mounted to the hardpoints, you just bolt through it.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On May 30, 2014, at 11:08 AM, bob88 <marty.crooks(at)comcast.net> wrote:
http://forums.matronics.com/viewtopic.php?p=424037#424037
Posted: Fri May 30, 2014 7:41 am Post subject: Seatbelt hardware |
A few thoughts:
- I considered the cabin top too thin to do a countersunk screw hard point
for the front shoulder belts. I added about 1/8" of additional glass,
perhaps a foot square or so, on the inside of the cabin, flared enough at
the edges so it looked ok.
- On the cabin top I squared off the hard point screw head a little, then
used flox in the countersunk hole. The screw head was just below flush so
some flox is on top. After sanding I put a thin layer of glass over the top
of the screw head. After that set some micro to fair everything in. I was
worried that about the screw head spinning in the countersunk hole when
tightening the harness attach nut and screwing up the paint job.
- I used Hooker Harness for the RV-10 as I had them in my RV-8A and like
them.
Carl
woxofswa
Posted: Fri May 30, 2014 12:38 pm Post subject: Re: Seatbelt hardware |
I dremeled slots aligned with the slot in the screw head and embedded a finish nail to prevent the screw from turning.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
speckter(at)comcast.net Guest
Posted: Fri May 30, 2014 2:05 pm Post subject: Seatbelt hardware |
Don't you think Van did his engineering on the belt mount?
Gary
[quote] On May 30, 2014, at 11:40 AM, "Carl Froehlich" <carl.froehlich(at)verizon.net> wrote:
A few thoughts:
them.
Carl
bwestfall
Joined: 22 Oct 2008 Posts: 131 Location: Portland, OR
Posted: Fri May 30, 2014 2:16 pm Post subject: Seatbelt hardware |
Not to mention I think it's been tested a few times as well with adequate
performance for the off field events that were survivable.
-Ben
Posted: Fri May 30, 2014 3:49 pm Post subject: Seatbelt hardware |
I did the same.
On 5/30/2014 4:38 PM, woxofswa wrote:
Posted: Fri May 30, 2014 3:50 pm Post subject: Seatbelt hardware |
I always consider Van to have a good design. I prefer to do such very
simple things to make sure I'm not violating some assumption Van may have
made or that I see as perhaps marginal. In this case a added a few layers
of glass to make sure in my countersinking zest I did not violate the
assumed depth or purity of the countersink hole.
There are examples however of the Van's design not being adequate. The
obvious one here are the doors. If everything works just right there will
be no problem. It has been demonstrated however that this presents a
practical risk as doors have departed in flight. For any RV-10 I recommend
installing or back fitting a system like the PlaneAround latch. Other
common sense things include adding 3/16" tinnermans under the door hinge
screw heads where the mounting screw relies on a thin piece of fiberglass
with a countersink that tends to extend through the material. One good gust
of wind catching a door and those screw heads might pull through.
But with all such things, we each must do what is needed so that we don't
worry about some aspect of the build every time we hop in the plane.
Carl
Posted: Fri May 30, 2014 4:00 pm Post subject: Seatbelt hardware |
Well, I assumed he did but then extended the thinking to assume that the back seat belts could be mounted the same way(!?)
So I created two new hardpoints for the rear seat belts by cutting out a the same size as the original hardpoints.
That circle cut thru the outer layer of glass and the honeycomb. Then I filled in the hole with flox and glassed it over.
Kitlog
Hope I never have to find out if my engineering assumptions were sound.
On 5/30/2014 6:04 PM, Gary wrote:
[quote] | Quote: | --> RV10-List message posted by: Gary <speckter(at)comcast.net> (speckter(at)comcast.net)
Gary
| [b]
flying-nut(at)cfl.rr.com Guest
Posted: Fri May 30, 2014 5:25 pm Post subject: Seatbelt hardware |
For the front seats the 'requirement' to have the shoulder harness attach point higher than the shoulder makes the cabin top the only likely fastening point. For the back seat that 'requirement' is met by the cable attachment. The drawback to the back seat arrangement is that the cable goes through the baggage compartment. Moving the attach point to the aft cabin top .... with suitable hardpoint installed ..... saves some weight and provides the same safety margin as the front shoulder harness. I never gave it much thought or I'd have done the cabin top mod too.
Linn .... somewhat late to the party
On 5/30/2014 8:00 PM, Bill Watson wrote:
[quote] Well, I assumed he did but then extended the thinking to assume that the back seat belts could be mounted the same way(!?)
Kitlog
| Quote: | | Quote: | --> RV10-List message posted by: Gary <speckter(at)comcast.net> (speckter(at)comcast.net)
Gary
Checked by AVG - www.avg.com
05/30/14 [b]
