Riveting the elevator trim reinforcement plate.
indigoonlatigo(at)msn.com
PostPosted: Sat Jan 14, 2006 9:00 pm    Post subject: Riveting the elevator trim reinforcement plate. Reply with quote
I have a silly question. I started to back rivet the elevator reinforcement
plate to the skins and did two rivets with the size called out in the plans
and both rivets bent over. They appear too long. I did the math with the
two skins adding to 0.048" and the rivets being a 3/32 diameter. By this
calculation I need a rivet of 3.1 sixteenths in length. The plans call for
a 3-3.5. I shot a 3-3 and it was straight but border line on shop head
length.
Back riveting is supposed to be a no brainer, but why did two of them bend
over and on the second one, I really concentrated. Did anyone have this
problem?
JOhn G. 40409
rv10(at)tpg.com.au
PostPosted: Sat Jan 14, 2006 9:39 pm    Post subject: Riveting the elevator trim reinforcement plate. Reply with quote
G'day,
bend over and on the second one, I really concentrated. Did anyone
have this problem?
Not necessarily a no-brainer. I have certainly found that rivets can
still be bent over.
A trick I use was one shown to me at my initial RV Workshop to ensure
that you are back-riveting straight down on the rivet. If you have the
set angled to the side you can very easily bend over a slightly long
rivet. Link below:
http://www.bravo.net.au/~samrv6/tech%20topics.html
Have fun,
Scott Lewis
RV-10 40172
Adelaide, South Australia
Albert Gardner
PostPosted: Sun Jan 15, 2006 3:06 am    Post subject: Riveting the elevator trim reinforcement plate. Reply with quote
I think you should consider a set of rivet gages: one to ensure correct
length and the others to make sure the shop head is formed properly. Van's
does a good job of properly calling out rivet sizes in the plans but you
should be prepared to verify/change the size if necessary.
Albert Gardner
40422
Subject: Riveting the elevator trim reinforcement plate.
problem?
JOhn G. 40409
RV-9A N872RV
RV-10 N991RV
